Compass From a Coffee Cup
Intro: Compass From a Coffee Cup
Lets imagine that you have just bought your favorite cup of coffee. You're in bliss right? But then, you are so taken up with your coffee that you wander out of town, and you are now in the middle of nowhere and wondering what to do. So, you whip out that used coffee cup and make a compass!
This is a surprisingly simple project, and is very fun to do. For those of you who have children, this would be a good beginner's science project. This project can also prove useful (despite the silly scenario I gave you).
Let's begin...
Let's begin...
STEP 1: What You'll Need
To do this, you will need:
A coffee cup
A sewing needle
A magnet
Cork
Water
You will use:
Scissors
Tape
A coffee cup
A sewing needle
A magnet
Cork
Water
You will use:
Scissors
Tape
STEP 2: Make the Vessel
The coffee cup will be the vessel for the project. It will hold the water and support the compass.
First, draw a line about 1 inch from the bottom of the cup around the cup. Then cut the cup so that you have an inch of cup wall left.
STEP 3: Magnetize the Needle
This is perhaps the most important part. In a regular compass, the needle always points north. To replicate this, we must change the polarity of the material and rearrange the order of the atoms of the needle by magnetizing it to point north.
Place your magnet on a flat surface (table) and slowly pull the needle across it on the north side of the magnet. To get any effect, you must repeat this at least 20-60 times. You get more of an effect if you repeat the step more, for example, 100 times is better than 50.
STEP 4: Floater for the Needle
Use the scissors to cut a small amount of cork, about 1/8 of an inch in size. Then tape you magnetized needle on top. We're ready to go!
STEP 5: Finish Up
Fill the cup with water so that it is almost full. Then gently place the bit of cork and needle in the middle of the cup. Give the compass a little bit of time to settle (make sure it is lying on a level surface). The needle should point north. You can check its accuracy with a regular compass. Have fun navigating with your new compass!
2 Comments
ericscrum 13 years ago
http://en.wikipedia.org/wiki/Magnet
sfcsarah 13 years ago
