Introduction: Composter From Old Washing Machine
In this Instructable, we will teach you how to make a composter from an old washing machine. After our old washing machine failed us, we had to get rid of it. To keep it out of the landfill, we turned it into a composter for our garden. This composter spins, to tumble the compost without getting your hands dirty.
Materials:
- Old washing machine (we only need the drum and the rear ball-bearings)
- 2x6 studs
- Long screws
- Scrap wood or plastic for lid
Tools:
- Screwdriver and drill bits
- Circular saw
- Bandsaw
- Chisel
Step 1: Prepare the Washing Machine
The washing machine (front loading) has a plastic cover that holds the drum in place. This plastic cover is attached to the bearings, which we want to keep. So we carefully used a chisel to remove the plastic so there is only a small amount of plastic surrounding the bearings.
Step 2: Remove the Paddles
Next we removed the paddles inside the drum and plugged large holes with plastic. We removed the paddles, but it isn't necessary.
Step 3: Ball Bearing Holder
We cut the 4x6 into 2 trapezoids that joined to make a bigger trapezoid and then repeated to a total of two large tapezoids. Then we cut out a semicircle from each of the 4 pieces to form a holder. It is then used to sandwich the ball bearings in place. See pictures above.
Step 4: Add Supports
Next, we cut supports out of 4x6 that attach to the ball-bearing holder. The first photo shows the bottom-half of the ball bearing holder. The top half is then screwed to the bottom half. We also added legs to the supports at an angle, so the drum can hold more compost. I would recommend increasing the backwards slope or angle, so the drum can hold more.
Step 5: Lid
We made a lid to keep creatures out and to keep compost in when we use it. This lid is made from scrap materials and is friction fit, but you can also make one from wood or plastic.
Step 6: Add Compost
As a final touch we added in our organic food waste. Since the drum has ball bearings, it can spin and you can tumble the compost for perfect results.
