Conceptual Makeup
Intro: Conceptual Makeup
This makeup is suppose to allow room for creativity so I will not focus on the colors that I used but rather the application process. I have used this idea on myself for halloween, for avant garde photo shoots, I've added fake blood to the 'pierced' spots for an added gory effect. It's really up to you how you want to expand this makeup. Hope you enjoy this instructable ^_^
**THE LAST STEP CONTAINS A VIDEO OF THE MAKEUP**
www.MakeupArtistryByFred.com
STEP 1: Materials
Materials
(Makeup can be purchased at MAC Cosmetics)
(Rivets & Ribbon can be purchased at a Craft store)
Brushes, fluffy and flat
Moisturizer
Paintpot, a base product for holding color and shadow
Powder
Foundation
Eyebrow pencil
Body paint
Eyeshadow
Eyeliner
False Lashes
Cosmetic glue
Makeup sponge
Lip pencil
Rivets
Velveteen ribbon
Scissors
Moisturizer
Powder
Foundation
Eyebrow pencil
Body paint
Eyeshadow
Eyeliner
False Lashes
Cosmetic glue
Makeup sponge
Lip pencil
Rivets
Velveteen ribbon
Scissors
STEP 2: Moisturize
Set out all of your tools and makeup and prepare your skin. Keeping your skin healthy is crucial, and it's especially important when applying makeup that's used for body painting. Cover your whole face with your favorite moisturizer.
STEP 3: Brow Cover Up
This look begins by turning your face into a blank canvas. That means making your eyebrows disappear! This step is all about alternating layers of paintpot with layers of powder. Use a flat brush to apply the paintpot product to your brows, then a fluffy brush to apply powder. Alternate paintpot and powder until you have applied a sufficient amount of layers and the hairs are completely covered. Then, gently, apply foundation or concealer over them, to return them to your own skin color.
STEP 4:
With the brows gone, it's time to re-draw them, dramatically! Hold the eyebrow pencil against your nose, and without drawing, use it to plot the path of the new arch. Make a tiny dot at the inside of your eye, at the top of the eye, and at the outside of the eye. Then, connect the dots into a swooping new eyebrow. Keep the shape simple- about 1/4" wide at the inside of the eye, tapering off at the outside of the eye. Fill in the brow, and repeat with your other eye.
STEP 5:
Now it's time for color! Use a medium gauge fluffy brush, and add white body paint underneath the brows. Start with white to make the brow look even more lifted and exaggerate the arching shape. Paint the white on, then use a stippling technique to create even coverage- just gently dab the tips of the bristles against your face.
STEP 6:
Add orange body paint beneath the white, and use the stippling technique to blend the colors together. Draw the orange out past the corners of your eyes, a bit further than you took the white. Bring the orange down to the top of your eyelid. The reason why I'm using a body paint is because it has more color saturation than a regular eyeshadow would.
STEP 7:
Using a tapered blending brush you can deepen the intensity of the look by adding black & brown eyeshadow into the crease of your eye. Filling in the crease with black adds dimension. And blending the black out with brown adds for a nicely blended look.
STEP 8:
Cover your eyelids with a layer of paintpot, then add turquoise. By applying the paintpot first, you give the blue a chance to really pop and also makes the makeup stay and not crease.
STEP 9:
Create a winged out eyeliner over the blue, with black eyeliner. I used a sharp angled brush with a dark black gel eyeliner. You can use the type that brushes on, a liquid liner, or a pencil. Bring the line on the upper lid out and up. Add a thick coat of mascara. Then line the inside of your lower lid, also called the waterline as well.
STEP 10:
The final step for adding color to your eyes is to apply a thin line of turquoise shadow to the lower eyelid. Pulling some of the black liner into the blue will add for a diffused look.
STEP 11:
Add a bead of the cosmetic glue(DUO GLUE) to the inside of the false lashes. The glue dries clear, so while you don't want to make a goopy mess, you can be generous with the amount of glue. Press the false lashes right against your own, and avoid blinking while they dry.
STEP 12:
While the lashes set, you can add blush.
STEP 13:
Use a sponge, or one of your brushes to add hot pink body paint along your hair line and down onto your forehead. Fade the pink out as you bring it down onto your forehead.
STEP 14:
Time to do your lips! With such colorful eye makeup, keep the lip relatively mild. Use yellow paint and a neutral pencil to color your lips.
STEP 15:
Glue the rivets onto your face. Place two over each eyebrow, and one right above your nose. Add three underneath each eye, and one on either side of your nostrils, about halfway up your nose. Use the cosmetic glue, and give the rivets a few moments to dry.
STEP 16:
Cut lengths of the velvet ribbon that are long enough to run from the upper rivets to the lower rivets. Dab both ends of the cut ribbon into the cosmetic glue, then press them into the rivets. The glue dries quickly, but work slowly, holding each ribbon in place for about 30 seconds to set them. Create a basket weave with the ribbons, working from the outside of your eye in, towards your nose. Once the glue is dry, the ribbons will be surprisingly sturdy, but until then, they are very fragile. Hold your face as still as possible until all the ribbons are completely set.
10 Comments
trinagirl 9 years ago
Thainna Jubiry Rios 10 years ago
sabu.dawdy 11 years ago
svarma3 11 years ago
KathyTackettPhoto 11 years ago
Sara_Tw_Sykes 11 years ago
xx
RemarkableJane 12 years ago
dreadyjazz 12 years ago
TalitaPeres 12 years ago
Penolopy Bulnick 12 years ago
