Introduction: Conch Shell Pendant Night Light
My Dear Instructables Crazy People:),
Ahh..it feels so good to make a lighted object after such a long time. In reality I never stopped thinking about making lamps & lightings but I was giving a trial in other areas of creativity. :D
"When you want something the universe conspires in helping you achieve it"- The Alchemist.
Isn't it so true?
I wanted to make a different styled lamp. I think some of my ideas were unique yet I was not motivated for a go-ahead until 2 days back When I found a big conch shell while cleaning my backyard where I keep my garden supplies (Soil etc.). It reminded me of my first visit to a sea shore in South India, where I found this conch shell. I was a kid and the feeling was no less than finding a Genie lamp of Aladdin that time
And I decided to use the shell for making a new lamp, a different one, a pendant.
Lets get started. Oh.. please vote for me if you like this ible :).
Isn't it so true?
Step 1: Gathering the Required Stuff
You would need following items to make a night light like this: (You can check some items in the image above)
NOTE: Please ignore the chain in the image above, I initially thought of using the chain to hang the shell but later I chose the metal tube and found it a much better option
Lets make some prepration now in the next step
- A Conch Shell.
- A Nose Plier.
- Earthing or Ground Wire.
- A metal tube (Thickness like a pencil).
- Some wires for lighting.
- LED 1 watt with driver or LED bulb small enough to go inside the shell. I had a spare LED fixture which I bought for lighting my almirah. I found it suitable for this job.
- Insulated tape (May not be required in your case)
Step 2: Wrap the Shell
You may have noticed the picture in step 1 that the shell looks dirty and has lots of dust on it. I used some liquid dish washing liquid using an old toothbrush and cleaned the shell as good as I could. See Image 1.
It might have been easier to just drill a hole in the shell and hang it but I did not want to hurt the natural beauty of the shell and decided to wrap it using wire (The idea came from a jewelry pendant made using a tiny conch shell, probably artificial.)
You are almost done, Lets jump to next step for making arrangements to hang the shell and put some light in it.
- Take around 2 feet of wire and create a square-inside-square design as shown in Images 2a-2d using nose pliers.
- Hold the design right below the shell and wrap the shell such that if you hold the wire from top, the shell should not fall down (Image 3)
- After wrapping is done, cut off access wire keeping a little extra to make a small square design at the top( Image 3).
Step 3: Hang and Light Up
The idea of using the metal tube instead of chain was to hide the electric wire as much as possible. Lets attach the tube with wire & light and complete the lamp.
Like I said earlier, you can choose a better method of lighting the shell, I chose this because most of the stuff was already available with me.
Some tips:
Thanks
- I took the LED fixture & removed its outer cap. I glued the reflective glass of the fixture using instant glue (Image 1).
- Take earth wire about 1.25 feet (a little longer than metal tube) and insert it inside the pipe. (Image 2)
- From one end, bend the wire like a hook (Image 3)
- Attach the LED with the electric wire, insert the wire inside the metal tube, put the LED inside the shell.
- Hang the shell by hooking up the wire from the metal tube.
- Cut off access wire from other end keeping a little to create a loop for hanging the pendant (Image 4).
- The ready lamp should look like Image 5
Some tips:
- No two shells are same, if you get one, you may have to adjust the way you wrap wire around it.
- I chose LED because I had one and it fits perfectly inside the shell, you may have to try some options depending on the shell you got.
- If you can get thick copper wire, that would look even more awesome.
Thanks
