Introduction: Concrete Dots
Using ShapeCrete Concrete Mix, create unique concrete steps.
Step 1: Materials
- ShapeCrete Concrete Mix
- Tin Foil Pan
- Non-stick cooking spray
- Container for mixing
- Decorative pieces
Step 2: Prepare the Form
Spray the tin with non-stick spray.
Step 3: Create a Design
For this style, the glass pieces are put on the bottom of the pan. It is easier to preplan the design before doing the next steps.
Step 4: Prepare the ShapeCrete Concrete Mix
Follow the directions of the ShapeCrete. Mix it for casting. Make sure that there are no clumps when mixing.
Step 5: Add the Concrete to the Form
Carefully pour the concrete into the sprayed tin with the design pieces at the bottom. You will need to add the concrete carefully as it can move the design pieces. Let the design sit for at least 24 hours.
Step 6:
Remove the tin and let the concrete continue to dry. Use a tooth brush to remove concrete that is covering your glass pieces.
