Concrete Fingerboard Skate Park
Intro: Concrete Fingerboard Skate Park
This is a super simple project that has been a huge hit. Here's a quick overview. Check it.
Our nephew wanted a TechDeck half-pipe for his birthday this year. We thought we'd kick it up and build him his very own real concrete fingerboard bowl park. The goal was to create a unique park from materials we had on hand. At 60 lbs., this park weighs a wee bit more than our nephew.
Materials:
tub/form (we used scrap 3/4" plywood and spray glued some plastic film to it)
bowl(s)
caulking
styrofoam
ready-mix concrete
spray silicone or some type of mold release
and of course, duct tape
Materials:
bowl(s)
caulking
styrofoam
ready-mix concrete
STEP 1: 1. Create the Form
Create a negative mold of your desired park shape.
We built a tub from scrap 3/4 plywood and spray glued some plastic film to it. To create the bowl shapes, we used 1 larger wooden bowl and 2 smaller glass bowls. The transitions/gaps where shaped from a few chunks of styrofoam and duct tape.
Note: The mold needs to be smooth, so the concrete can release when cured.
We used caulking to make smooth transitions and rounded corners. Use your finger and a little water to smooth out generous beads/globs of caulking. Let the caulking dry overnight before pouring concrete.
STEP 2: 2. Pour Concrete
Mix and pour the ready-mix concrete.
We used a full 60lb. bag of basic post concrete mix since we had that on hand. It worked ok, but cracked because the form was too thin (specs state minimum of 2" thick). The trick to a smooth final finish to knock all of the air bubbles out. We tamped everything well with a small stick. Then we beat on the outside of the form with a hammer. You will see the bubbles rise to the surface. Let sit for at least 24 hours. (we rushed it and cracked the main bowl. as an easy fix, we glued the pieces to plywood with liquid nailsback in business)
STEP 3: 3. Remove Form
Carefully remove your form. If you have any cracks or bubbles, fill with non-sanded grout or other concrete patch/filler.
Add the finishing details like:
-stickers
-coping
-rails
-extensions
-etc
-stickers
-coping
-rails
-extensions
-etc
STEP 4: 4. Shred!
"Cannon Ball Park" in action:
59 Comments
Ben DangerH 7 years ago
danx_the_drummer 11 years ago
PotatoCoffee 12 years ago
reref 12 years ago
dylankunaikennedy 12 years ago
peterthomsen 12 years ago
THE total BEAST 12 years ago
Sakrete 13 years ago
tech deck123 13 years ago
splatman 13 years ago
Another layer of mesh along the bottom, and/or some rods, to reinforce it from the bottom as well.
One way to use less 'crete, (and make it lighter too,) is hide chunks of Styrofoam in the thick parts. Just make sure they don't surface when you tap the mold during the air-purge routine. Tying them to the mesh may help. Another way is to screw small boards across the top of the mold, with legs holding down the Styro-chunks thru the 'crete. When done air-purging, unscrew said boards, remove the legs, and fill in their "footprints".
Or let the Styro-chunks surface (cut holes the bottom re-mesh for this), and remove them after the 'crete's set.
If you wish to reduce the amount of 'crete needed (or get more volume), but don't care about weight, use rocks from your backyard in place of the "Styro-chunks".
You can make your concrete a different color by using pigment. Pigment may be pricey, so you may want to leave that out.
http://www.directcolors.com/concretepigment/
or buy it at a hardware store.
toiletmamba 13 years ago
Plan0 13 years ago
gl0rious 13 years ago
Jebotepatak 14 years ago
Wonderful work masters just wondering how heavy is the concrete park?
This would be a perfect excuse to buy a tech deck!! =)
Thank You
GianniMora 14 years ago
-M
andrewdover 15 years ago
dcfingerboards 14 years ago
