Introduction: Concrete Lamp (6)
Hi, this is a very easy concrete lamp, built from a shaker bottle...
Step 1:
For this one I used a plastic shaker bottle. A 30mm hole was made with soldering iron at the bottom for the socket to be mounted.
Step 2:
You need cord with switch and plug pre-installed, an E27 socket and a chair protective pad. Make a 14mm hole to pass the cord through, and attach the pad which protects the cord from extreme bending. Then make a 8mm hole at the bottom of the socket, again pass through the wires and connect them
Step 3:
Insulate all holes with super glue or hot glue. In my case, just my two cents...
Step 4:
Use the bulb to secure socket in place. I used a socket corral as a spacer.
Step 5:
Prepare and will the shaker.
Step 6:
Next day, cut the shaker with a soldering iron and carefully remove it.
Step 7:
Wet sand the bottom with 100 or 150 grit wateproof sand paper and the body (you can skip this one) with 600 or 800 grit.
Step 8:
After some fine-sanding it looks perfect, isn't it? Dont forget the self adhesive rubber pads.
Step 9:
Add a bulb that you like. Enjoy!
