Introduction: Connect Linkit One to Ubidots for IoT
IoT is the USP of this board. In this instructable, I'm going to gather readings of temperature and Altitude from MS5607 sensor and upload it to the ubidots site and see how it can be used to in the world of internet
Step 1: Prerequisites
1. You'll need a WIFI router with internet connection. In case you don't have a router, you can even using mobile hotspot with active data connection
2. You will need a IoT service provider. I am using ubidots. Please go to the website an sign up for a free account
Step 2: Connections
We need to connect the sensor to the board.
For that we do the following connections:
Vin -> 3V3
GND -> GND
SCL -> AD5/SCL
SDA -> AD4/SDA
Also, we connect the WIFI antenna to the board because we will be uploading the data to the internet
Vin -> 3V3
GND -> GND
SCL -> AD5/SCL
SDA -> AD4/SDA
Step 3: Ubidots Configuration
Once you log in to your ubidots account, you'll need to create a new source
I have created a new source linkit with 2 normal variables - Temperature, Altitude
Now once the variables are created, click on the small i in the corner of each variable and note down the variable IDs
Also, go to your profile and click on a new short term token. A new token will be created. Take a note of token id as well
You are now good to go to the coding step
Step 4: Code
I have uploaded my code. But firstly you'll need to add Intersema.h header file in your librarias
Now you will have to replace the token id and the 2 variable Ids in the code
Also you will have to replace the SSID and password of your WIFI in the code
Step 5: Compile, Run, Output
If everything goes well, you will receive the data in real time at ubidots like in the picture
You can now use this data to plot graphs, perform analysis, or further processing as you wish
