Introduction: Connect Raspberry Pi to Oregon Scientific BLE Weather Station
Monitor room and outdoor temperature with a BLE thermometer connected to Raspberry Pi
Browsing the web, I found a myriad of temp sensors that you can interface easily with Raspberry Pi. And came across many tutos detailing how to interface these sensors wirelessly to RPi with a 433MHz RF transmitter/receiver kit.
Monitoring the temperature wit RPi was fun but I wanted also the ability to read the temperature at a glance, without having to turn on my computer and open a web page.
Moreover these 433MHz RF kits didn't sound very efficient (low range) and reliable reading users feedback.
Then I came upon Oregon Scientific Wireless Indoor / Outdoor Thermometer with Bluetooth Low Energy Connectivity (EMR211) and thought that it was the perfect match.
I can connect the Weather Station base to my Raspberry Pi3 through Bluetooth Low Energy. I can monitor up to 3 sensors connected to the base + temperature at the base.
Step 1: Oregon Scientific Weather Station BLE Protocol
An easy way to explore the BLE services exposed by the Weather Station is to use a BLE Scanner app on a smartphone or tablet. Here I'll be using Nordic Semiconductor's nRF Connect on Android.
For people that aren't familiar with BLE, you might want to start with this Bluetooth Low Energy introductory guide. This will help you understand terminology like GATT, service, and characteristic.
With the BLE Scanner app, you wilI find all BLE devices surrounding you. And you will see that the Oregon Scientific Weather Station is adverting itself as IDTW211R.
If you connect to the Weather Station, you'll get the list of services exposed by the device.
- Generic Access UUID: 0x1800
- Generic Attribute UUID: 0x1801
- Proprietary Service UUID: 74e7fe00-c6a4-11e2-b7a9-0002a5d5c51b
- Device Information UUID: 0x180A
- Battery Service UUID: 0x180F
The service that matters to us is the Proprietary Service (UUID: 74e7fe00-c6a4-11e2-b7a9-0002a5d5c51b). So we click on this service and get the list of characteristics exposed by the service.
The relevant characteristic for our application is UUID: 74e78e10-c6a4-11e2-b7a9-0002a5d5c51b (INDOOR_AND_CH1_TO_3_TH_DATA).
As indicated in the properties, this characteristic isn't readable but offers an indication service. And we will have to enable the indication through the corresponding Client Characteristic Configuration Descriptor (UUID: 0x2902).
It turns out that indication/notification have to be enabled for all the characteristics of the device to start getting any indication.
Step 2: Connect the Raspberry Pi3 to the BLE Weather Station
Now that we have a better idea on how to retrieve temperature data through BLE, let's try to get our Raspberry Pi talking to the Weather Station.
BLE on Raspberry Pi
I'll be using the Raspberry Pi3 (which integrates a WLAN/BT controller) with Raspbian Jessie with Pixel 2016-09-23.
The version of bluez (5.23) in this Raspbian release is quite outdated and we will have to upgrade to later version of bluez to work with Bluetooth Low Energy.
Download bluez 5.43 and install required dependencies:
sudo apt-get update
sudo apt-get install -y libglib2.0-dev libdbus-1-dev libudev-dev libical-dev libreadline-dev
wget http://www.kernel.org/pub/linux/bluetooth/bluez-5.43.tar.xz
tar xvf bluez-5.43.tar.xz
Configure, build and install bluez
./configure
make
sudo make install
And finally reboot the Raspberry Pi.
Now let's verify that the bluetooth stack is up and running with the cmd hciconfig dev
And then confirm that we can scan for BLE devices: sudo hcitool lescan
We should see our Weather Station adverting as IDTW211R.
Next step is to connect to the Weather Station:
sudo gatttool -b <BLE ADDRESS> -t random -I
You should get a new command prompt with the BLE address in between brackets.
connect
You should get a "Connection successful" and the prompt gets colored
Once connected, we can run some commands to get more details on the device. For instance, the primary command will list the services exposed by the device.
Collecting data from the Weather Station
As explained earlier to start getting indications on the INDOOR_AND_CH1_TO_3_TH_DATA (UUID: 74e78e10-c6a4-11e2-b7a9-0002a5d5c51b), we have to enable Indication/Notification on all characteristics.
We enable indication by writting 0x0002 (0x0001 for notification) in Client Characteristic Configuration Descriptor (UUID: 0x2902) of each characteristic. Write shall be placed in little endian format so: char-write-req 0200
In return, you should start getting indications/notifications. The relevant ones for us are INDOOR_AND_CH1_TO_3_TH_DATA indications (so handle 0x0017).
Indication handle = 0x0017 value: 01 05 01 15 01 ff 7f ff 7f 7f 7f 7f 7f ff ff 7f 7f 7f 7f 7f
Indication handle = 0x0017 value: 82 7f 7f 7f 21 01 f8 00 24 01 ba 00 ff 7f ff 7f ff 7f ff 7f
For each round of indications, we get two data packets of 20 bytes each. The most significant byte indicates the type of data (Type 0 or Type 1). See last picture for more details on the data packets.
Step 3: Python Script to Retrieve Weather Station Data
Now that we succeeded to get the data out of the Weather Station, let's automate the whole process and make some sense of the data.
Here is a python script that connect to the Weather Station, retrieve the data and extract the temperature of the Weather Station base and wireless sensor coming with it.
This script makes use of bluepy library providing an API to allow access to Bluetooth Low Energy devices from Python. So you will have to install this module before executing the script: https://github.com/IanHarvey/bluepy#installation
Usage
The script can be executed with the MAC address passed as argument or without argument.
In this latter case, the script will perform a scan and look for a device adverting as IDTW211R. It has to be executed with root privilege because bluez requires root privilege for scan operations.
python bleWeatherStation.py [mac-address]
sudo python bleWeatherStation.py
#!/usr/bin/python
# -*- coding: utf-8 -*- # Connect to Oregon Scientific BLE Weather Station # Copyright (c) 2016 Arnaud Balmelle # # This script will connect to Oregon Scientific BLE Weather Station # and retrieve the temperature of the base and sensors attached to it. # If no mac-address is passed as argument, it will scan for an Oregon Scientific BLE Weather Station. # # Supported Oregon Scientific Weather Station: EMR211 and RAR218HG (and probably BAR218HG) # # Usage: python bleWeatherStation.py [mac-address] # # Dependencies: # - Bluetooth 4.1 and bluez installed # - bluepy library (https://github.com/IanHarvey/bluepy) # # License: Released under an MIT license: http://opensource.org/licenses/MITimport sys import logging import time import sqlite3 from bluepy.btle import *
# uncomment the following line to get debug information logging.basicConfig(format='%(asctime)s: %(message)s', level=logging.DEBUG)
WEATHERSTATION_NAME = "IDTW211R" # IDTW213R for RAR218HG
class WeatherStation: def __init__(self, mac): self._data = {} try: self.p = Peripheral(mac, ADDR_TYPE_RANDOM) self.p.setDelegate(NotificationDelegate()) logging.debug('WeatherStation connected !') except BTLEException: self.p = 0 logging.debug('Connection to WeatherStation failed !') raise def _enableNotification(self): try: # Enable all notification or indication self.p.writeCharacteristic(0x000c, "\x02\x00") self.p.writeCharacteristic(0x000f, "\x02\x00") self.p.writeCharacteristic(0x0012, "\x02\x00") self.p.writeCharacteristic(0x0015, "\x01\x00") self.p.writeCharacteristic(0x0018, "\x02\x00") self.p.writeCharacteristic(0x001b, "\x02\x00") self.p.writeCharacteristic(0x001e, "\x02\x00") self.p.writeCharacteristic(0x0021, "\x02\x00") self.p.writeCharacteristic(0x0032, "\x01\x00") logging.debug('Notifications enabled') except BTLEException as err: print(err) self.p.disconnect() def monitorWeatherStation(self): try: # Enable notification self._enableNotification() # Wait for notifications while self.p.waitForNotifications(1.0): # handleNotification() was called continue logging.debug('Notification timeout') except: return None regs = self.p.delegate.getData() if regs is not None: # expand INDOOR_AND_CH1_TO_3_TH_DATA_TYPE0 self._data['index0_temperature'] = ''.join(regs['data_type0'][4:6] + regs['data_type0'][2:4]) self._data['index1_temperature'] = ''.join(regs['data_type0'][8:10] + regs['data_type0'][6:8]) self._data['index2_temperature'] = ''.join(regs['data_type0'][12:14] + regs['data_type0'][10:12]) self._data['index3_temperature'] = ''.join(regs['data_type0'][16:18] + regs['data_type0'][14:16]) self._data['index0_humidity'] = regs['data_type0'][18:20] self._data['index1_humidity'] = regs['data_type0'][20:22] self._data['index2_humidity'] = regs['data_type0'][22:24] self._data['index3_humidity'] = regs['data_type0'][24:26] self._data['temperature_trend'] = regs['data_type0'][26:28] self._data['humidity_trend'] = regs['data_type0'][28:30] self._data['index0_humidity_max'] = regs['data_type0'][30:32] self._data['index0_humidity_min'] = regs['data_type0'][32:34] self._data['index1_humidity_max'] = regs['data_type0'][34:36] self._data['index1_humidity_min'] = regs['data_type0'][36:38] self._data['index2_humidity_max'] = regs['data_type0'][38:40] # expand INDOOR_AND_CH1_TO_3_TH_DATA_TYPE1 self._data['index2_humidity_min'] = regs['data_type1'][2:4] self._data['index3_humidity_max'] = regs['data_type1'][4:6] self._data['index3_humidity_min'] = regs['data_type1'][6:8] self._data['index0_temperature_max'] = ''.join(regs['data_type1'][10:12] + regs['data_type1'][8:10]) self._data['index0_temperature_min'] = ''.join(regs['data_type1'][14:16] + regs['data_type1'][12:14]) self._data['index1_temperature_max'] = ''.join(regs['data_type1'][18:20] + regs['data_type1'][16:18]) self._data['index1_temperature_min'] = ''.join(regs['data_type1'][22:24] + regs['data_type1'][20:22]) self._data['index2_temperature_max'] = ''.join(regs['data_type1'][26:28] + regs['data_type1'][24:26]) self._data['index2_temperature_min'] = ''.join(regs['data_type1'][30:32] + regs['data_type1'][28:30]) self._data['index3_temperature_max'] = ''.join(regs['data_type1'][34:36] + regs['data_type1'][32:34]) self._data['index3_temperature_min'] = ''.join(regs['data_type1'][38:40] + regs['data_type1'][36:38]) return True else: return None def getValue(self, indexstr): val = int(self._data[indexstr], 16) if val >= 0x8000: val = ((val + 0x8000) & 0xFFFF) - 0x8000 return val def getIndoorTemp(self): if 'index0_temperature' in self._data: temp = self.getValue('index0_temperature') / 10.0 max = self.getValue('index0_temperature_max') / 10.0 min = self.getValue('index0_temperature_min') / 10.0 logging.debug('Indoor temp : %.1f°C, max : %.1f°C, min : %.1f°C', temp, max, min) return temp else: return None def getOutdoorTemp(self): if 'index1_temperature' in self._data: temp = self.getValue('index1_temperature') / 10.0 max = self.getValue('index1_temperature_max') / 10.0 min = self.getValue('index1_temperature_min') / 10.0 logging.debug('Outdoor temp : %.1f°C, max : %.1f°C, min : %.1f°C', temp, max, min) return temp else: return None def disconnect(self): self.p.disconnect() class NotificationDelegate(DefaultDelegate): def __init__(self): DefaultDelegate.__init__(self) self._indoorAndOutdoorTemp_type0 = None self._indoorAndOutdoorTemp_type1 = None def handleNotification(self, cHandle, data): formatedData = binascii.b2a_hex(data) if cHandle == 0x0017: # indoorAndOutdoorTemp indication received if formatedData[0] == '8': # Type1 data packet received self._indoorAndOutdoorTemp_type1 = formatedData logging.debug('indoorAndOutdoorTemp_type1 = %s', formatedData) else: # Type0 data packet received self._indoorAndOutdoorTemp_type0 = formatedData logging.debug('indoorAndOutdoorTemp_type0 = %s', formatedData) else: # skip other indications/notifications logging.debug('handle %x = %s', cHandle, formatedData) def getData(self): if self._indoorAndOutdoorTemp_type0 is not None: # return sensors data return {'data_type0':self._indoorAndOutdoorTemp_type0, 'data_type1':self._indoorAndOutdoorTemp_type1} else: return None
class ScanDelegate(DefaultDelegate): def __init__(self): DefaultDelegate.__init__(self) def handleDiscovery(self, dev, isNewDev, isNewData): global weatherStationMacAddr if dev.getValueText(9) == WEATHERSTATION_NAME: # Weather Station in range, saving Mac address for future connection logging.debug('WeatherStation found') weatherStationMacAddr = dev.addr
if __name__=="__main__":
weatherStationMacAddr = None if len(sys.argv) < 2: # No MAC address passed as argument try: # Scanning to see if Weather Station in range scanner = Scanner().withDelegate(ScanDelegate()) devices = scanner.scan(2.0) except BTLEException as err: print(err) print('Scanning required root privilege, so do not forget to run the script with sudo.') else: # Weather Station MAC address passed as argument, will attempt to connect with this address weatherStationMacAddr = sys.argv[1] if weatherStationMacAddr is None: logging.debug('No WeatherStation in range !') else: try: # Attempting to connect to device with MAC address "weatherStationMacAddr" weatherStation = WeatherStation(weatherStationMacAddr) if weatherStation.monitorWeatherStation() is not None: # WeatherStation data received indoor = weatherStation.getIndoorTemp() outdoor = weatherStation.getOutdoorTemp() else: logging.debug('No data received from WeatherStation') weatherStation.disconnect() except KeyboardInterrupt: logging.debug('Program stopped by user')
1 Person Made This Project!
- Voogel made it!
36 Comments
5 years ago
Thanks a lot,
I've been able to get the data from a BAR218HG station on RPI Zero with IoT pHat using your instructable.
I'd like to retrieve the past data (24h or 1week) like Weather@Home android app.
Do you have any hint on how to query the main station to get that data ?
Thanks again
Reply 4 years ago
On a BAR218HG the history is obtainable through handle 0x11.
Writing (0x80,0x00,0xff) to 0x11 will get 7 day history, (0x80,0x00,0xfe) last 24 hours.
The middle character is the channel: 0x00 internal temp/humidity, 0x01 internal pressure, 0x10 ch1 temp/humidity, 0x11 ch2 temp/humidity.
I have found that after a reset day 8 of the history is lost so for following days you get days 9-7-6-5-4-3 -2.
Description of a factory reset is a bit misleading as it does not reset/clear the history.
Below is example of data from the last 24 hour history
0x11: 003db10035a60036a60036a90036ab00363d
0x11: 0038af0036b30036b80035c00034c800333d
0x11: 0033ca0033cb0033cb0034ca0033c500343d
0x11: 002ec40034c40035c60035c90034cc00343d
0x11: 0029c50035be0037be0037be0038b500393d
0x11: 013d5227542756275e27612768276f2774273d
0x11: 01357b277f2785278d2792279027902792273d
0x11: 012d922797279a27a327a827ae27ac27ab273d
0x11: 0125a627a627a727a627a927ab27ab27a7273d
0x11: 103db4003ba6003ca5003ca8003caa003b3d
0x11: 1038ae003bb2003bb6003bbd003bc3003a3d
0x11: 1033c5003ac90039cb0039c7003ac4003b3d
0x11: 102ec3003bc3003bc5003bc8003aca003b3d
0x11: 1029c2003bbe003cbe003cc0003db5003d3d
0x11: 113db10038a60038a60039a90038ac00383d
0x11: 1138af0038b40038b90038c10037c900373d
0x11: 1133cb0037c90037c90037c70037c300383d
0x11: 112ec20039c20039c40039c60038c700383d
0x11: 1129c0003abc003bbb003bbb003bb2003b3d
Hope the above helps
Reply 2 years ago
Hi, I want to get a history from the device as well.
How did you figure out this information about the device (0x80,0x00,0xff)?
I bought device BAR218HGX. It has service(74e7fe00-c6a4-11e2-b7a9-0002a5d5c51b) with bunch of characteristic.
I can write the value into some of them but it doesn't make any result.
I am not sure with an order of steps that I should do.
Should I enable all (indication/notification) characteristics before the writing values?
I am not sure about the accurate characteristic which I need to write value.
Could you look at my information below (image)?
Maybe you will have some ideas or tips for me.
Reply 5 years ago
You're welcome. Glad to hear that you were able to get the code to work on Rpi Zero.
No, I wasn't able to figure out how to retrieve historical data.
So I am running the python script every hour thanks to cron utility and storing the results in a SQLite database on my RPi.
3 years ago on Step 3
Huge thank you to Arnø for sharing this and also for the inspiration!!
I have an old Oregon Scientific RAR213HG with a couple of sensors and found that Arnø's script is fully compatible with this model. I recently built a Homebridge box using Raspberry Pi Zero W board and so my Oregon sensors are exposed to HomeKit
I changed the script to capture reading from sensors 0,1,2 and save into a SQLite DB, then scheduled it to run every 5 min via crontab. I've never used Python, SQLite or cron before plenty of examples in the Internet
For Homebridge I used homebridge-cmd4 plugin to expose sensors
The plugin executes a very simple bash script that reads the most recent reading of a specified sensor from the DB
Works perfectly!
3 years ago
Hi,
thanx for the script, does anybody have a modified script that also grabs the humidity for in- and outdoor?
regards Richard
3 years ago
This is really great thanks! I've got it running on a Raspberry Pi Zero W, and was wondering how to add battery level to the variables it returns? I can read it from the command line, but wasn't sure how to get it in the Python code:
`sudo gatttool -b [mac-address] -t random --char-read --handle=0x0031`
4 years ago
Hi i have a little problem.
I run script to get temperature and humidity every 10 minutes from my RAR213HG, it's ok.
But after time, maby 1-2 days, Station not respond to requests, and not detected by adroid application. resolution is to power off station, and when power on. Mabe need to pair ?
Reply 4 years ago
another solution, it to push "up" button to run bluetooth searching process on station, as in manual.
4 years ago
Thanks ! I successeful run script on Ubuntu server with Xiaomi bluetooth to read my RAR213HG.
But need to read channels 4 and 5. anybody try to read this data ?
Reply 4 years ago
Believe the data is on handle 0x0020. I've only got 3 channels so am unable to confirm if the data structure is the same as handle 0x0017
0x0e: 001b034000000000
0x17: 01e0004600de00fd7f313d357d00c0382e463539
0x17: 82347d7df000b60090003900ea00b600fd7ffd7f
0x20: 01fd7ffd7ffd7ffd7f7d7d7d7df0ff7d7d7d7d7d
0x20: 827d7d7dfd7ffd7ffd7ffd7ffd7ffd7ffd7ffd7f
0x1a: ab270000000001
0x1d: 1112021515050b00000000000000000000000000
5 years ago
Hi, Appreciate you sharing this. I have set this up on my RP3 at home and things were going great. However after a couple of days the RP3 stopped receiving temps from the weather station. see terminal output below. I had already edited the cron file to automate this every 5 minutes, so thinking this might be to frequent for the weather station I changed this to once every hour. Unfortunately the same thing happens. I also tried to change the timeout in self.p.waitForNotifications (as in below comment) but no change also. The only way I have found is to remove the batteries from the weather station and reboot it, then it all works fine again. Any help would be appreciated. Thanks.
Reply 4 years ago
Hello Thomas,
Sorry for the late reply. I missed your message.
Yes, I did face hangs of the Weather Station base where Rpi can connect over BLE and enable indication/notification but the base wouldn't throw any indication. And it's exactly what you're facing.
Increasing notification timeout doesn't help. You have to reset the base to get it back to work.
These hangs disappeared once I upgraded to Raspbian Jessie with Pixel (2016-09-23) and bluez 5.43.
Please note also that only one single device can be connect to the Weather Station base at a time. If you're already connected to the base with the Weather@Home mobile app, then you won't be able to connect your Rpi.
Hope you will be able to solve your problem.
Cheers,
Arnø
Reply 4 years ago
No worries Arn0, I appreciate you getting back to me. It is good to know I am not the only one who had these issue! Presently I have just set the cron job up to run every hour, at this interval the weather stations seems to be okay. I will experiment with the Raspbian upgrade and see how I go.
Reply 4 years ago
Hi Thomas - just to share I have that script running with a cron every 5 minutes for many months and it is fairly stable. I've faced hangs a couple of times but suspect they appeared when station was taken far away from RPI (too long range for BLE). It somehow never recover from that even when station is brought back close enough
Reply 4 years ago
Thanks for the info Piben, I might try it one last time with a clean install of Raspbian and the weather station sitting 30cm from the pi before I try and intercept the 433Mhz signal.
Reply 4 years ago
Hi Arnø, I tried with the version of raspbian you suggested (Jessie 2016-09-23) and Bluez 5.43, but still no good. I am curious, how often do you get temp data from your setup? I think I will have to go down the path of using a 433Mhz receiver to read the temperatures. BLE was a neat idea, but doesn't seem reliable enough at the moment. Thanks.
Reply 4 years ago
I have a cron job capturing temp data every hour.
It's been running for more than 6 months without any hang.
Is your weather station close to your Rpi? Another user reported me that he was facing some hangs every time he would move the weather station away from his Rpi.
Good luck with 433Mhz receiver :)
5 years ago
Excellent tutorial Arnø! For me it worked on first trial with a RAR218HG Oregon scientific weather station. I only had to implement slight changes to report humidity - though all framework was there and ready for that. Awsome.
Thanks a lot for sharing!
Reply 4 years ago
Thanks a lot ARNO for this contribution !
Hi Piben,
I'm trying to do the same on a RAR213HG,
What changes have you made to get Humidity datas ?
Does someone has found a workaround for the connectivity issue ? (to avoid remove battery/reset Oregon Base sensor)
