Connect Your Xbox 360 Online Using Your Laptop (Simplified for Vista ONLY)
Intro: Connect Your Xbox 360 Online Using Your Laptop (Simplified for Vista ONLY)
There are a few other Instructables showing you how to do this, but none are used with vista. So, being very confused at the time, I didn't know what to do. Fortunately, I figured it out, and decided to create an Instructable on how to do it.
To do this, you will need:
- An Xbox 360
- A laptop (Vista in this instructable)
- An Ethernet cord long enough to connect the 360 to the laptop
- Wireless router / Wireless internet connection
- Some essential snacks while playing with buddies online (my favorite part)
STEP 1: Manage Network Connections
First, you need to have a wireless connection on your laptop. When you are sure your connection to the internet is good, right-click the network icon on the taskbar and select Network and Sharing Center.
NOTE: Take this time to be sure the connection is good enough in your desired place, some routers are stronger than others.
Next,on Network and Sharing Center, select Manage Network Connections on the left side.
Onto the next step.
Onto the next step.
STEP 2: Bridge the Network
When you bring up the Manage Network Connections page, it will have at least two connection icons listed in it, the Wireless Connection, and the Local Area Connection(Or LAN).
Highlight them both, and then right click. From there, click Bridge Connections, or something like that. Give it a few minutes to bridge the connections. Once the two connections are bridged, go to the next step.
STEP 3: Setup the Xbox
Now its time to hook up the Xbox. When you have your Xbox in the desired place, get the Ethernet cable and plug it in. Then, connect it to your laptop. Now, simply go to the settings tab on the Xbox, and select Network Settings. Run the test, and it should be successful.
So what did bridging the connections do?
By creating a bridge, you connected the wireless and LAN connections together. The LAN provides a network to any computer connected to it (In this case, the Xbox), and the bridge will connect the Internet connection, and the Local Area Connection together providing internet. Easy, huh? Easy enough to not understand.
STEP 4: Sit Back & Relax
Now get your bag if chips and pop, sit back, call a few buddies and play Xbox Live with each other. Congratulations! you saved yourself $100!
186 Comments
thebestgamer760 3 years ago
JefferyD1 7 years ago
wambamit344 9 years ago
getting the same error message when trying to bridge using pdanet as my connection ...where should I focus ?
zachs3 9 years ago
didnt work either
Emir. 9 years ago
does this cost extra when the internet payments come pls answer!
JamesR1 9 years ago
holy crap didnt think this would actaully work but it did thanks man your a lifesaver
JimSavLickinAss 11 years ago
demen 15 years ago
willguillermogonz 15 years ago
jayman242 12 years ago
Astro Zombie 14 years ago
odom41 14 years ago
PuddleOfMudd25 14 years ago
BIGDADDY12 12 years ago
aarteaga3 12 years ago
moosterboi 12 years ago
breakell666 12 years ago
swiedemer 12 years ago
wilsonater 15 years ago
