Introduction: Connecting Spectre to Max/msp
Spectre by Audiofile Engineering is one of the best metering options for OSX. It’s got all kinds of meters (VU, BBC, LU, Nordic, K12, etc.) and look amazing.
So how do we get max/msp to talk to Spectre?
Step 1: AUNetSend
Spectre uses AUNetSend by Apple. On the max side of things, you don’t even need to know where this Audio Unit file is. A vst~ object with AUNetSend as its only parameter works just fine. You can see in the picture how that looks.
Step 2: Open
The open message will open the Apple supplied dialog of AUNetSend, which you use to connect Spectre with max/msp. If you open it in max/msp, it will tell you it’s listening.
Step 3: Start Spectre
After Spectre is running, go to Preferences... - Audio. A dialog will pop up.
Step 4: Configure Network
In the Audio Preferences of Spectre, make sure Network is checked. Then click on Configure.
Step 5: Connecting
As you can see, Spectre is "Not Connected". Select the AUNetSend in the Directory list (if it isn’t already) and click on Connect. Max (or rather OSX) will probably ask you if all this is allowed. Of course we click Allow.
Step 6: Connected!
Now Spectre and max/msp are connected! Yes! All the audio you send to Spectre (via the vst~ object) will now be displayed by those gorgeous meters you selected.
In the last step you find a small example max patch to try this yourself.
Step 7: Example Max Patch
----------begin_max5_patcher----------
920.3ocyX1saaBCFF93jqBD6zrHv.Ax1Q8FnmLsiplhbBtItiXxrcRSaU609
7OXBrBTm1NqToDGrM1u9wu9iO5SiG4ur7Hh468Mua7FM5owiFopRVwnpqG4u
EdbUAjo5leA9.ZJGtzehtwCPJAtE0Yaj8awjBDWcmgUUdaIgyvOptiv3oAm5
6hBLAwVrCxWsASV27lDsVtmaFpnpZ0UweXGRuB78mn+baQIj668qWO1TDCQ3
PNtjHuGyralyETzJtdv.wgBw4EFEIKhDWARl3ABlFTOt3b0xtb4ceMxudjnB
bvQzEHBbYAp4pfAOfxW.4bJd4dN5zuXU.uh3RpVrGUdqoZS8MG9hRx59HeqN
x1TR4V0SCIAczFR.wJJuUnXIkUrRTxf2qJDDVVRJwLTM7aMH6IXNi+flJA51
ed73SEpued7jywLtFhIuzqcrUqsLjfN8VI84sXXAtKzKTyuN40lHmNVCOW+N
pnjLYQbl1dMqaCE3BvP0jcukkp29ZPXPGssUrcHa6qoAS6tcnZ6eVmshEtIr
XiPA2FmK62xE+wsbrBbNhNXDt1FpvdCVMnWIctxdLKUYYBhzQel2sYIaHyhI
FmInKHP7Wcb2RJtY.wv2ARHn6EhvHAN5nZM3uCS98K1+n.PyGEXC+pNFNDES
BzQsizAwyTm+5KDdZreCcU6tuhJ8XedXggJD5qj9hWbmvIwUvoJbDXt7zkWZ
zfrA3D1HEmfKwAhiyIcRmHWac.goVXcBcBd1sAxDFmAeZl6.SRrEfIvIfY0C
qJPWJbYtEwZhm+4xEzi4vUmSZNuchuyhjOjvKIw7cWqiYehahGXhy9.uq940
H9OPj7O91Y14lKmJENQIlvMUo9XQXzjDc.zzA22GJNQib5pj4WtVN6RtnDWI
LWjMye1iDC3DO4rHpsAt77+tPouiMjsHFCtF8pcjxcHx+wCUCh0vLU3k3T0S
mhTAgCy54zjcGlT2pu5EAa+FupoWVeaFwJ2SWYDa0tmWXs.xQLNlTm4zMlSD
M6yFbdNp0aZliYxDyxqeCnWsWcNpIvB0D3D0.rfMgNiM.KXSnyXSpMxA3L3X
sbbCcxrPMogWVxI3hRNxrIbkUN1F7HMOwtQOg1pGGc1JvV8.bhd9Gqw.5IxM
54hJvbjsv48HGc5Fvc6NfnrpwToDQxW2URU+eslntDSzWpxTR7RvGvl9mppA
REYGwEoFsmpSs4XlLwaw7773+ZaUQNN
-----------end_max5_patcher-----------
