Introduction: Connecting the Itead Gps Shield to a Raspberry Pi 2
Hi, in this instructable I´m going to talk about connecting the Iteads Raspberry Pi GPS add on V 1.0 with a raspberry pi 2 using raspbian jessie and GPSD.
You can find the shield I used here.
Parts you need:
- A raspberry pi 2
- A SD card with raspbian jessie (my OS is from 23 November 2016, but this should work with other jessie distros)
- A NEO-6M gps micro with Serial communication.
- Internet access
Step 1: Step 1 : Setting Everything Up
The first thing you´ll need to do is open the serial port in the raspberry pi, for that you need to access the raspbian configuration menu. You can get there using the command sudo raspi-config and under Advanced Options chose A8 Serial in order to enable Serial connections.
The problem with these is that when booting, the raspberry will send unwanted data trough the port. to get around that you need to delete some stuff in cmdline.txt.
For that you should first take a backup using sudo cp /boot/cmdline.txt ~/cmdline.txt.bak
After, using sudo nano cmdline.txt , delete console=Serial0,115200 and kgdboc=Serial0,115200
To end this step, reboot the pi using sudo reboot
Step 2: Step 2: Installing Gpsd and Connecting the Add-on to the Pi
To install the gpsd service and clients to access the data use sudo apt-get install gpsd gpsd-clients
After the installation the file gpsd found in /etc/default must be corrected. In order to do this use the command sudo nano /etc/default/gpsd .
START_DAEMON must be true
USBAUTO must be false
DEVICES must be /dev/ttyAMA0
GPSD_OPTIONS must be "" (nothing
and GPSD_SOCKET must be /var/run/gpsd.sock
reboot again, if any of this instructions are missing in the file just add them.
Step 3: Step 3: Running Gpsd and the Client Cgps
Now you´re able to start the gpsd service using sudo service gpsd start
After powering the shield for the first time, give it 15/30 minutes in the open sky in order to triangulate the position.
Using cgps -s you should get a table just like the one in the picture
Best regards.
Carlos
