Introduction: Constellation Purse
If you like astronomy and stars why not carry them with you? :)
Hope you enjoy ^w^
Step 1: Materials
-Scissors
-Navy blue fabric
-black thread
-White thread
-a needle
-a zipper
-chalk
Step 2: Pattern
Draw your pattern.There is no right or wrong way to do it you can make it in any size :)
Step 3: Cut the Fabric
Draw the pattern on the fabric and cut.Don't forget to leave seam allowence!
The fabric I used was very sheer so I used a thicker fabric for the lining.If you are using a thick fabric you don't have to do that.
Step 4: Zipper
I chose to use a black zipper but white also works :) Place the zipper a bit below the fabric and sew.Then fold the fabric and sew again.Repeat this step for the other side.
Step 5: Constellation
I googled the star map and draw them on the paper then draw them on the fabic using the chalk.You don't have to draw them exactly the same.This is optional :)
Step 6: Sewing
NOTE: If you use a thicker thread.It looks better :)
First sew the main lines then sew little star shapes.Repeat it for both sides.
Step 7:
This step is optional I just didin't want the thread to show on the inside so I glued a sheer fabric over it.
Step 8: Edges
Put the right sides together and sew on the edges.Make sure that you open up the zipper.
Step 9: Last Step
So lastly place your purse vertically.You are going to sew like a triangle shape on both ends.Then cut the excess fabric.
Step 10: Done!
and you are done!Hope you enjoyed this little tutorial. :))
