Constructing Monolithic Domes on Google SketchUp
Intro: Constructing Monolithic Domes on Google SketchUp
As a follow up to my Geodesic Sphere tutorial, I shall illustrate how you can construct a special type of monolithic dome for your personal use.
The very first thing you need to do is to have Google SketchUp installed. You can download it for free at: http://sketchup.google.com/download/
Once installed, start the software
Set Conditions:
- Go to Edit > Edge Style > Disable Profiles
- Go to Window > Model Info > Units
- Set Format to Decimal > Meters
- Enable length snapping at 0.01m
- Enable display units format
- Enable angle snapping at 15.0 degrees
- Make all precision at 0.00m
Download SketchUp file for this tutorial
If the first host doesn't work, try here
The file is in WinRAR format (similar to WinZip) and can be downloaded for free here
Set Conditions:
STEP 1: Make the Base
Start by making two 48 sided circles, one at 20m and another at 18m. Delete the white planes to leave a hollow core.
STEP 2: Draw Two Arcs
Create a 24 sided arc with a bulge height of 10m and another one at 9.5m.
Click on the yellow boxes for details.
STEP 3: Simplifying the Framework
Now delete the inner circle base, and get rid of any unnecessary construction lines.
Now click on the yellow box.
STEP 4: The Monolithic Dome
If dome correctly, it will look something like this. If you orbit to the bottom of the dome, it should be perfectly hollow inside, with a noticeable thickness.
STEP 5: Creating Entrances - Part I
In the next steps, we will be creating 8 entrances for the dome.
1. Hide the two domes to reveal the circular base.
2. Make a cylinder 5m in radius, and 10m in height. Then select the cylinder, Right Click > Make Group.
3. Make 8 well-spaced lines 10m high.
STEP 6: Creating Entrances - Part II
Now select, copy, and paste the cylinder 7 times into the positions shown.
The center of the cylinder should connect with the top of the lines.
You can find the center of the cylinder by selecting the Move tool, then hovering over two points of the top circumference of the cylinder, and then over near the center.
Finally, move the center original cylinder to the last position.
STEP 7: Creating Entrances - Part III
1. Go to Edit > Unhide > All
2. Then triple click the dome
3. Right Click > Intersect > Intersect with Model
4. Select all 8 cylinders > RIght Click > Explode
STEP 8: Creating Entrances - Part IV
Now delete the cylinders, and delete your way to making entrances.
STEP 9: Finished Product
Voila!
7 Comments
EliasP18 7 years ago
Hi no one off the tutorial link working also where is the yellow box you talking about ? i can't see any yellow box on the SketchUp can you give pls a sample of the yellow box or print screen with the tools we suppose to use?
Greasetattoo 10 years ago
Making a protective cover for my GPS unit on my quadcopter!
I will print it, in ABS plastic!
thank you for the great tutorial!
ritzanab 10 years ago
Imperar 10 years ago
rickharris 13 years ago
Imperar 13 years ago
