DIY Automatic Ball-picking Machine
Intro: DIY Automatic Ball-picking Machine
Recently, we made a DIY ball launcher and got a lot of responses.
Then Makeblock share a ball-picking machine to answer our project.
They made it in their Makerathon.And it just cost 48hours.But still
insteresting enough to share with you!
So I share their article here now.(Original)
STEP 1:
List: (all materials are from Makeblock)
1. Beam 0824 (double-hole beam) 192 *1
2 .25 DC motor 6V/185RPM *2
3 .25 motor bracket *2
4 .Transmission fixed tray *2
5 .Timing pulley 90 T *2
6 .Patterned tires *2
(1) Install 25 DC motor into 25 motor bracket (2X).
(2) Install timing pulley into transmission fixed tray (2X).
(3) Install assembled timing pulley and transmission fixed tray on output shaft of motor (2X).
(4) Install assembled motor with wheel through beam 0824 (double-hole beam)
(5) Fit timing pulley with patterned tire
STEP 2:
1. Beam 0824-192 1
2. Bracket P3 1 3 Universal wheel 1
(1) Install bracket P3 in the mid-position of beam 0824-192.
(2) Install the universal wheel in the hole of bracket P3.
STEP 3:
1.Beam 0824-192 1
(1) Connect beam 0824 of drive wheel to that of transmission universal wheel through beam 0824-192
STEP 4:
1.Beam 0824 -160 6
(1) Install 6 beam 0824-160 in the positions respectively as shown in the picture.
STEP 5:
1.MECDS-150 steering gear *1
2.8mm shaft clamping apparatus *2
3. 8mm bearing bracket A *2
4. Optical axis D8*250mm *1
5. Washer 4*7*2mm *2
6. Bracket U1 *1
7. 8mm shaft wheel connection piece *2
8. Bearing 8*16*5mm *2
(1) Install 8mm bearing bracket A in corresponding positions of beam 0824-160 (2X).
(2) Install bearing 8*16*5mm into 8mm bearing bracket A (2X).
(3) Install 8mm shaft clamping apparatus with 8mm shaft wheel connection piece (2X).
(4) Fix 8mm optical axis on rotary disc of steering gear through one of 8mm shaft clamping apparatus.
(5) Install assembled steering gear and optical axis on 8mm bearing bracket and 8mm bearing.
(6) Install steering gear with bracket U1.
(7) Install the other 8mm shaft clamping device in the other side of 8mm shaft without clamping.
STEP 6:
1 Beam 0824 -192 *3
2 Beam 0824 -176 *1
3 Connecting rod *2
4 Beam 0824 -016 *2
5 Optical axis D4*80 *2
6 Shaft sleeve 4mm *4
7 Screw M4*80 *2
(1) Install two beam 0824- 016 on both sides of beam 0824 -176.
(2) Install three beam 0824-192 with assembled beam 0824-016&176.
(3) Install 4mm optical axis in corresponding position of beam 0824 -176, and fix it with shaft sleeve. (2X)
(4) Install screw M4*80 on screwed holes of beam 0824 - 016 (2X).
(5) Install connecting rods in corresponding positions (2X).
STEP 7:
1 Connecting rod *6
(1) Install assembled ball-picking mechanism with main body of ball-picking robot.
(2) Install connecting rods on main body (6X).
