Introduction: Contact Less Switch
Now we all know that the world has a very bad situation and people are scared for touching things.
So during the Lockdowns I made this contactless switch. Which is very easy to make and code.
This is very useful to stop spread of COVID-19.
I am Studying in 9th grade.
Step 1: Make the Connections!
- Connect the GND pin of the Ultrasonic to GND pin of Arduino.
- Connect the VCC pin of the Ultrasonic to the 5V pin of the Arduino.
- Connect the TRIGG pin of the Ultrasonic to the Digital pin 9 of the Arduino.
- Connect the ECHO pin of the Ultrasonic to the Digital pin 10 of the Arduino.
- Connect the GND and VCC pin of relay to the GND and 5V pin of Arduino.
- Connect the IN pin of the relay to the Digital pin 2 of Arduino.
- NOTE: The connections in the above Figure is Different.
Step 2: Time to Code!!
Use the Below code to programme the Arduino<br>
bool x = 0; //holds one of two values, true or false
int relayPin = 2; //defines PIN 2 as relay
const int trigPin = 9; //defines PIN 9 as trigPin of Ultrasonic sensor
const int echoPin = 10; //defines PIN 10 as echoPin of Ultrasonic sensor
long duration; //defines a variable
int distance; //defines a variable
void setup() {
pinMode(trigPin, OUTPUT); //sets trigPin as OUTPUT
pinMode(echoPin, INPUT); //sets echoPin as INPUT
pinMode(relayPin, OUTPUT); //sets relayPin as OUTPUT
Serial.begin(9600); //starts the Serial Communication
void loop() {
digitalWrite(trigPin, LOW); // Clears the trigPin
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10); // Sets the trigPin on HIGH state for 10 micro seconds
digitalWrite(trigPin, LOW); // Reads the echoPin, returns the sound wave travel time in microseconds
duration = pulseIn(echoPin, HIGH);
distance = duration * 0.034 / 2; // Calculating the distance
Serial.print("Distance: "); // Prints the distance on the Serial Monitor
Serial.println(distance);
// The minimum distance needed to activate the switch
if (distance < 10) {
x = !x;
if (x == 0) {
digitalWrite(relayPin, HIGH); // ON the Light
Serial.println("Light is OFF"); //prints light is OFF
if (x == 1) {
digitalWrite(relayPin, LOW); // OFF the Light
Serial.println("Light is ON"); //prints light is ON
delay(500);
}<br>Attachments
Step 3: Upload the Code and Test Them OUT!!!!
Plug the arduino to the computer and upload the code.
If you Like the Project Please VOTE me to the "CAN'T TOUCH THIS" CONTEST
