Introduction: Contact Staff
Here's a quick and simple contact staff you can put together with things you might have lying around the house.
Contact Staff is a form of object manipulation derived from contact juggling and traditional staff. It involves lots of moves done using your torso, rather than just your hands, to manipulate the staff. It's pretty sweet.
Contact staffs differ from regular staffs in their weight and handle type. From what I gather, the best contact staffs have solid cores, weighty ends, and sticky handles.
I wanted to learn contact staff after seeing members of the Vulcan (see vid below). But I didn't want to shell out $40-65 for a professional rig, and I wanted to see how much I liked spinning it before buying (or building) a fire rig. So I spent a few hours putting together this simple staff, and the weight and balance turned out pretty great!
Step 1: Supplies
A broom handle or solid wood dowel. Length is up to you, but it will likely fall between 3.5 and 5 feet. Check out this thread for a discussion of contact staff length. (Summary--your contact staff will probably be longer and heavier than your regular staff.)
Old bicycle tubes - I used 4 road tubes and 1 mountain tube. You could experiment to find the weight that works best for you. My staff is pretty heavy but I find that keeps it slow and helps me learn the moves.
Also:
Bike handlebar tape and electrical tape
Scissors
Flat head thumbtacks
Duct tape
Ruler
Sharpie
Muscle.
Step 2: Cut Down Your Bike Tubes
Cut off the section around the valve, then cut down the length of each tube so you can lay it out as one flat strip.
Step 3: Roll Tubes Onto Handle
Carefully roll the strips of tube onto the handle ends. It helps to wipe off some of the white powder that coats the inside of your tubes. Once you've got it started, make sure to roll really tight.
When you've gone as far as you can, cut a nice straight end and tack it down with your flat head tacks. Then cover that with a piece of duct tape for extra security.
Step 4: Finish Ends
Take your mountain bike tube and cut out the valve section. Procure a muscle-bound friend to stretch the tube around your staff end, leaving about 1" of excess at each end. If you yourself are of the muscle-bound variety, procure a lovely assistant to hold onto the staff while you stretch the tube over.
For a smoother look, we added 2 layers of covering tube to each end.
Step 5: Finish Ends
For a finished look on the ends, I trimmed each end of the covering tube to fit flush, then added a circle of black duct tape under the cover.
Because I thought of this after the fact, I rolled back the cover end to expose the raw end, covered it with the little duct tape disc, then rolled the cover back over for a finished end.
Step 6: Balance!
Find your balance point by balancing the staff on your finger. Mark this with a Sharpie.
Step 7: Add Handle Tape
Just like wrapping your bike bars. Measure equal distances out from the center line and mark those. I made a 20" handle, which used almost exactly one roll of bar tape. Wrap tightly from one marking to the other, finishing with electrical tape.
Step 8: Balance... Again!
Find that center point again and add a strip of bright electrical tape to it so you can see it while you spin.
Happy contact staff adventures.. you're done!
9 Comments
7 years ago
How much weight can handle?
7 years ago
Thank you so much :)
10 years ago on Step 8
Done! Thank you so much! It's a really great tutorial! :)
11 years ago on Introduction
I started doing this last year and then set it aside because something wasn't going the way I wanted it to - I don't remember what. Anyway, I came back to it today because I still didn't have a staff and didn't like the ones I saw online. It really went smoothly!
The couple of things I did differently:
1. I didn't have anyone to help with the ends, so I just put a roll of bike tubing against the baseboard where the wall met the floor and propped the other end of the handle against it so that it would hold steady (and not damage the wall) while I pushed the tube over the end.
2. I didn't have handlebar tape, so I used Ace grip tape. It was too tacky for me, though, so I just wrapped once more in Ace, then went over the top of the whole 20 inches in electrical tape. I might come to regret that over time with use, but for right now it's nice and smooth, while slightly grippy.
3. I just used one wide tube on each end instead of two smaller ones. nbd.
Thanks again for posting the excellent instructable!
12 years ago on Introduction
cool im probaly gonna learn how to do this now!
Awesome. Thanks so much for posting this!
I couldn't get ahold of bike tubes so I used two tennis balls at the ends which has been working just fine for practicing. My next staff will be shorter and with the tacky ended inner tubes though! :)
if you do build a fire contact staff please put up another instructable.
this one was fantastic!
13 years ago on Introduction
I have experimented using bicycle inner tubes as handle grips before and found that to help stretch the tube over something it helps a lot to blow compressed air up under the tube as you pull it on.
Reply 13 years ago on Introduction
nice tip! i'll try it with the next tools i make... thinking about making some poi with bike tubes. :)
