Introduction: Control Aurdoino With Any Remote Control
It's a project to control aurdoino with any remote control you want :]
Step 1: Tools We Need
!-arduino (any type)
2-led
3-330 ohm resistance
4-10 k ressitnce
5-IR Recsiver (3 bins)
Step 2: Hooking Up
//led
Hook up ardoino pin 13 to 330 ohm resistance then the led
//reciver
hook up the IR receiver (Depending on the type of the receiver )
left leg (Signal leg) to pin 11
the VCC and GND Are depending on the type of your receiver
//10k resistor
connect the 10 K resistor from the Vcc to the Signal leg
as a pull up resistor
Step 3: Code
add this library to your
arduino from here
https://github.com/z3t0/Arduino-IRremote
then download the code and burn it on your arduino
if you faced a problem in compiling just delete
IRrobotControl from your libraries
Any problem just leave a comment :)
