Introduction: Control Daikin AC From Anywhere With Beautiful UI and Losant
Hello,
In this instructable we will learn how to control Daikin air-conditioner from any point in the world using Losant IoT Enterprise Platform and their amazing UI dashboard
The ESP8266 is a low-cost Wi-Fi chip with full TCP/IP stack and MCU (microcontroller unit)
Step 1: How It Works
The microcontroller (ESP8266) connects Losant IoT platform and waits for input (user changes something in the dashboard) then the IR sensor sends information to the Daikin air-conditioner
Make sure the IR transmitter is as close as possible to the AC
Step 2: Required Parts and Components
Step 3: Assembling the B0X
- Drill 2 holes with screwdriver or drill or whatever is easy for you
- Hot glue the transmitter to one of the holes (the one which will point to the AC)
- Connect ESP8266 to the IR Transmitter
- Connect the USB cable to the ESP8266
- Run the USB cable through the other hole
- Close the case with 4 screws
- You are done :)
Wiring the IR Transmitter to the ESP8266
IR Transmitter - EPS8266
- (minus, GND) - GND
+ (plus, VCC) - VIN
S (DAT) - D2
Step 4: Setting Up the Device in Losant
- Create a device called IR Transmitter
- Add 5 device attributes
- Data type - Boolean with Name status
- Data type - Boolean with Name quiet
- Data type - Boolean with Name powerful
- Data type - Number with Name temperature
- Data type - Number with Name fan
Step 5: Making the Dashboard
Create a dashboard called AC DASHBOARD and Input Controls Block
Add 6 Controls
- Toggle Input with Label = Status, Template-ID = toggle-0, Dynamic Value, Device IDs/Tags = IR Transmitter, Attribute = status, Default value = false
Toggle Input with Label = Quiet, Template-ID = toggle-1, Dynamic Value, Device IDs/Tags = IR Transmitter, Attribute = quiet, Default value = false
Toggle Input with Label = Powerful, Template-ID = toggle-0, Dynamic Value, Device IDs/Tags = IR Transmitter, Attribute = powerful, Default value = false
Range Input with Label = Temperature, Template-ID = range-0, Min = 18, Max = 32, Device IDs/Tags = IR Transmitter, Attribute = temperature, Default value = 18
Range Input with Label = Fan, Template-ID = range-1, Min = 0, Max = 5, Device IDs/Tags = IR Transmitter, Attribute = fan, Default value = 0
Button trigger with Label = Send, On Click = Send Device Command, Device IDs/Tags = IR Transmitter, Command name = command, Payload = check below
Payload:
"status" : {{toggle-0}},
"quite" : {{toggle-1}},
"powerful" : {{toggle-2}},
"temperature" : {{range-0}},
"fan" : {{range-1}}
Step 6: Upload the Code to the ESP8266
You need to add the Losant library
Upload it to the ESP8266
Congratulations you can now control your AC from anywhere
#include <ESP8266WiFi.h>
#include <IRremoteESP826.h> #include <IRsend.h> #include <Losant.h> #include <ir_Daikin.h>const char *WIFI_SSID = "ssid"; const char *WIFI_PASS = "pass";
const char *DEVICE_ID = "device-id"; const char *ACCESS_KEY = "access-key"; const char *ACCESS_SECRET = "access-secret";
WiFiClientSecure wifiClient; IRDaikinESP dakinir(D2);
LosantDevice device(DEVICE_ID);
void handleCommand(LosantCommand *command) { Serial.println(); Serial.print("Command received: "); Serial.println(command->name);
if (strcmp(command->name, "command") == 0) {
JsonObject &payload = *command->payload; payload.printTo(Serial); char json[400];
StaticJsonBuffer<200> jsonBuffer;
payload.printTo(json, sizeof(json));
JsonObject &root = jsonBuffer.parseObject(json);
if (!root.success()) { Serial.println("parseObject() failed"); return; }
bool status = root["status"]; bool quiet = root["quite"]; bool powerful = root["powerful"];
int16_t temperature = root["temperature"]; int16_t fan = root["fan"];
if (status) { dakinir.on(); } else { dakinir.off(); } dakinir.setFan(fan); dakinir.setTemp(temperature); dakinir.setQuiet(quiet); dakinir.setPowerful(powerful);
dakinir.send(); } }
void connect() { Serial.print("Connecting to "); Serial.println(WIFI_SSID);
WiFi.begin(WIFI_SSID, WIFI_PASS);
while (WiFi.status() != WL_CONNECTED) { delay(500); Serial.print("."); }
Serial.println(); Serial.println("WiFi connected"); Serial.println("IP address: "); Serial.println(WiFi.localIP());
Serial.println(); Serial.print("Connecting to Losant...");
device.connectSecure(wifiClient, ACCESS_KEY, ACCESS_SECRET);
while (!device.connected()) { delay(500); Serial.print("."); }
dakinir.begin();
Serial.println("Connected successfully"); }
void setup() { Serial.begin(115200);
device.onCommand(&handleCommand);
connect(); }
void loop() { bool toReconnect = false;
if (WiFi.status() != WL_CONNECTED) { Serial.println("Disconnected from WiFi"); toReconnect = true; }
if (!device.connected()) { Serial.println("Disconnected from Losant"); Serial.println(device.mqttClient.state()); toReconnect = true; }
if (toReconnect) { connect(); }
device.loop(); }
