Introduction: Control Lights by Voice Commands and Keys
About: Hello, my name is Carlos. I have a YouTube channel where I share my projects in https://www.youtube.com/c/carlosvolt
In this tutorial we will see how to create a device to control lights by voice commands, with a module from geeetech.
Step 1:
In this tutorial we will see how to create a device to control lights by voice commands, with a module from geeetech, designed for this purpose. We will see how to assemble this device on a PCB manufactured by PCBWay. We will analyze the hexadecimal commands for its configuration, and the source code. Finally, we will test its operation.
Electronic components
Arduino Nano
Voice recognition module
Voice recognition module command
  • 0x00–>Enters waiting mode for some command
  • 0x01 –>Delete instructions from group 1
  • 0x02 –>Delete instructions from group 2
  • 0x03 –>Delete instructions from group 3
  • 0x04–>Delete instructions from all 3 groups
  • 0x11–>Start recording group 1 instructions
  • 0x12–>Start recording group 2 instructions
  • 0x13–>Start recording group 3 instructions
  • 0x21–>Import group 1 for using voice commands
  • 0x22–>Import group 2 for using voice commands
  • 0x23–>Import group 3 for using voice commands
  • 0x24–>Check the recorded groups
  • 0x31–>Change speed to 2400 bps
  • 0x32–>Change speed to 4800 bps
  • 0x33–>Change speed to 9600 bps
  • 0x34–>Change speed to 19200 bps
  • 0x35–>Change speed to 38400bps
  • 0x36–>Switch to common mode
  • 0x37–>Switch to compact mode
  • 0xbb–>Module version information
Parameters
  • Voltage: 4.5-5.5V
  • Current: <40mA
  • Digital interface: 5V TTL
  • Analog interface: 3.5mm mono-channel microphone jack + microphone pin interface
  • Size: 30mm x 47.5mm
KIT
This kit consists of a voice recognition module, a USB serial module, cables and a microphone.
Male pins
Eight Push Buttons
Female Pines
Dupont cables female male
Electret microphone
8 channel relay module
Characteristics
Allows you to control the on/off of high-power equipment (household appliances). Works perfectly with Arduino, Pic or any other digital system.
Within the wide variety of projects that we can carry out with Arduino, we may want to control high voltage or high amperage components, such as light bulbs or water pumps, which cannot be controlled directly with Arduino. In these cases it is necessary to use Relays, these devices allow controlling high voltage loads with a small signal.
The module has 8 high quality Relays, capable of handling loads up to 250V/10A. Each channel has electrical isolation by means of an optocoupler and a status indicator LED. Its design facilitates work with Arduino, as well as with many other systems such as Raspberry Pi, ESP8266 (NodeMCU and Wemos), Teensy and Pic. This Relay module activates the normally open output (NO: Normally Open) when receiving a logical “0” (0 Volts) and deactivates the output with a logical “1” (5 Volts). For Arduino and Relay programming, it is recommended to use timers with the “millis()” function and thus not use the “delay” function that prevents the system from continuing to work while a relay is activated/deactivated.
Among the loads that can be handled are: light bulbs, luminaires, AC motors (220V), DC motors, solenoids, solenoid valves, water heaters and a wide variety of other actuators. It is recommended to make and verify the connections before powering the circuit, it is also good practice to protect the circuit inside a case.
Technical data
8 independent channels
8 1-pole 2-throw relays
The relay coil voltage is 5 VDC
LED indicator for each channel (lights up when the relay coil is active)
Current activated: the control circuit must provide a current of 15 to 20 mA
It can be controlled directly by logic circuits
Screw connection terminals (clamps)
Logic signal input terminals with 0.1″ male headers.
Food and consumption
The easiest way to power this module is from Vcc and GND of the Arduino board, keeping the Jumper in place, so JD-Vcc = Vcc. This connection has two important limitations:
The electrical isolation provided by optocouplers is lost, increasing the possibility of damage to the Arduino if there is a problem with the relay loads.
The current consumed by the relay coils must be supplied by the Arduino board. Each coil consumes about 90 mA and the four together add up to 360 mA. If we add to this the consumption that other outputs can have, we are very close to the 500 mA that a USB port can supply. In this case the Arduino should be powered with an external source, which increases the current limit to 1 A (in the case of the Arduino UNO).
The safest way is to remove the jumper and power the relay board with two sources: the one from the Arduino board connected to Vcc and a second source, with the positive to JD-Vcc and the negative to GND, without being connected to the Arduino board. This connection has the following advantages:
There is complete isolation between the load and the Arduino.
All relay power is taken from the second source and not from the Arduino or the USB port.
Tickets
The inputs to the board can be connected directly to the digital outputs of the Arduino board. The only precaution to take into account is that when the Arduino is started by being powered up, the pins are automatically configured as inputs and it may happen that, for a very short period of time between the start-up and the correct configuration of these pins as outputs, the control inputs to the relay module remain in an undetermined state. This can be avoided by connecting a pull-up with a 10K resistor to Vcc on each input, which ensures a HIGH state during start-up.
PCB
Download PCB –> 8 channel light control via bluetooth
Circuit
Source code
The serial port speed is set to 9600bps, this is the speed at which the voice recognition module is configured.
With
Serial.write(0xAA);
Serial.write(0x37);
We send the serial command AA 37 and switch the module to compact mode.
With
Serial.write(0xAA);
Serial.write(0x21);
We send the AA 21 command and choose the group to work on the module, remember that there are 3 groups of 5 voice commands but only one group can be worked on at a time.
color(255,102,0); we call the color function and pass it 3 parameters that will be used to give the voltage to the 3 pwm pins connected to the pwm switches.
Step 2: Source Code
int led3 = 3;
int led4 = 4;
int led5 = 5;
int led6 = 6;
int led7 = 7;
int led8 = 8;
int led9 = 9;
int led10 = 10;
int led3estado = 0;
int led4estado = 0;
int led5estado = 0;
int led6estado = 0;
int led7estado = 0;
int led8estado = 0;
int led9estado = 0;
int led10estado = 0;
byte com = 0;
int estadoBoton11 = 0;
int estadoBoton12 = 0;
int estadoBotonA5 = 0;
int estadoBotonA0 = 0;
int estadoBotonA1 = 0;
int estadoBotonA2 = 0;
int estadoBotonA3 = 0;
int estadoBotonA4 = 0;
int estado11 = 0;
int estado12 = 0;
int estadoA5 = 0;
int estadoA0 = 0;
int estadoA1 = 0;
int estadoA2 = 0;
int estadoA3 = 0;
int estadoA4 = 0;
//Pulsadores
int botonPin11 =11;
int botonPin12 =12;
int botonPinA5 =A5;
int botonPinA0 =A0;
int botonPinA1 =A1;
int botonPinA2 =A2;
int botonPinA3 =A3;
int botonPinA4 =A4;
void setup()
Serial.begin(9600);//Velocidad a la que trabaja el módulo de reconocmiento de voz
pinMode(led3, OUTPUT); // Establece el led3 como una salida
pinMode(led4, OUTPUT); // Establece el led4 como una salida
pinMode(led5, OUTPUT); // Establece el led5 como una salida
pinMode(led6, OUTPUT); // Establece el led6 como una salida
pinMode(led7, OUTPUT); // Establece el led6 como una salida
pinMode(led8, OUTPUT); // Establece el led6 como una salida
pinMode(led9, OUTPUT); // Establece el led6 como una salida
pinMode(led10, OUTPUT); // Establece el led2 como una salida
digitalWrite(3,HIGH);
digitalWrite(4,HIGH);
digitalWrite(5,HIGH);
digitalWrite(6,HIGH);
digitalWrite(7,HIGH);
digitalWrite(8,HIGH);
digitalWrite(9,HIGH);
digitalWrite(10,HIGH);
delay(2000);
//Pines como entradas para los pulsadores
pinMode(botonPin11, INPUT_PULLUP);
pinMode(botonPin12, INPUT_PULLUP);
pinMode(botonPinA5, INPUT_PULLUP);
pinMode(botonPinA0, INPUT_PULLUP);
pinMode(botonPinA1, INPUT_PULLUP);
pinMode(botonPinA2, INPUT_PULLUP);
pinMode(botonPinA3, INPUT_PULLUP);
pinMode(botonPinA4, INPUT_PULLUP);
//Comando para cambiar al modo compacto
Serial.write(0xAA);
Serial.write(0x37);
delay(1000);
// Importa el grupo 1
Serial.write(0xAA);
Serial.write(0x21);
void loop() // Correr una y otra vez
estadoBoton11 = digitalRead(botonPin11);//Leemos el pulsador para ver su estado
estadoBoton12 = digitalRead(botonPin12);//Leemos el pulsador para ver su estado
estadoBotonA5 = digitalRead(botonPinA5);//Leemos el pulsador para ver su estado
estadoBotonA0 = digitalRead(botonPinA0);//Leemos el pulsador para ver su estado
estadoBotonA1 = digitalRead(botonPinA1);//Leemos el pulsador para ver su estado
estadoBotonA2 = digitalRead(botonPinA2);//Leemos el pulsador para ver su estado
estadoBotonA3 = digitalRead(botonPinA3);//Leemos el pulsador para ver su estado
estadoBotonA4 = digitalRead(botonPinA4);//Leemos el pulsador para ver su estado
///Botón 11 precionado///
if (estadoBoton11 == LOW) {
//Leemos el estado del pin 3
led3estado = digitalRead(led3);
// Si el led está apagado se cumple esta condición
if (led3estado == LOW) {
// Y enciende el led 3
digitalWrite(led3, HIGH);
} else {
// Por el contrario lo apaga
digitalWrite(led3, LOW);
delay(350);//Delay antirrebote
///Botón 12 precionado///
if (estadoBoton12 == LOW) {
//Leemos el estado del pin 4
led4estado = digitalRead(led4);
if (led4estado == LOW) {
// Y enciende el led 4
digitalWrite(led4, HIGH);
} else {
digitalWrite(led4, LOW);
///Botón A5 precionado///
if (estadoBotonA5 == LOW) {
//Leemos el estado del pin 5
led5estado = digitalRead(led5);
if (led5estado == LOW) {
// Y enciende el led 5
digitalWrite(led5, HIGH);
} else {
digitalWrite(led5, LOW);
///Botón A0 precionado///
if (estadoBotonA0 == LOW) {
//Leemos el estado del pin 6
led6estado = digitalRead(led6);
if (led6estado == LOW) {
// Y enciende el led 6
digitalWrite(led6, HIGH);
} else {
digitalWrite(led6, LOW);
///Botón A1 precionado///
if (estadoBotonA1 == LOW) {
//Leemos el estado del pin 7
led7estado = digitalRead(led7);
if (led7estado == LOW) {
// Y enciende el led 7
digitalWrite(led7, HIGH);
} else {
digitalWrite(led7, LOW);
///Botón A2 precionado///
if (estadoBotonA2 == LOW) {
//Leemos el estado del pin 8
led8estado = digitalRead(led8);
if (led8estado == LOW) {
// Y enciende el led 8
digitalWrite(led8, HIGH);
} else {
digitalWrite(led8, LOW);
///Botón A3 precionado///
if (estadoBotonA3 == LOW) {
//Leemos el estado del pin 9
led9estado = digitalRead(led9);
if (led9estado == LOW) {
// Y enciende el led 9
digitalWrite(led9, HIGH);
} else {
digitalWrite(led9, LOW);
///Botón A4 precionado///
if (estadoBotonA4 == LOW) {
//Leemos el estado del pin 10
led10estado = digitalRead(led10);
if (led10estado == LOW) {
// Y enciende el led 10
digitalWrite(led10, HIGH);
} else {
digitalWrite(led10, LOW);
////Lectura de datos desde módulo de reconocimiento de voz
while(Serial.available())
//Captura los caracteres del puerto serial y se los asigna a la variable "com"
com = Serial.read();
//Se compara la variable "com"
switch(com)//Estructura de control switch, case
case 0x11://Si el valor es 0x11
led3estado = digitalRead(led3);//Leemos el estado del pin 3
// Si el estado es igual a LOW
// Enciende el led
} else {
break;
case 0x12://Si el valor es 0x12
led4estado = digitalRead(led4);//Leemos el estado del pin 4
// Enciende el led
} else {
break;
case 0x13://Si el valor es 0x13
led5estado = digitalRead(led5);//Leemos el estado del pin 5
// Enciende el led
} else {
break;
case 0x14://Si el valor es 0x14
led6estado = digitalRead(led6);//Leemos el estado del pin 6
// Enciende el led
} else {
break;
case 0x15://Si el valor es 0x15
led7estado = digitalRead(led7);//Leemos el estado del pin 7
// Enciende el led
} else {
break;
