Introduction: Control Line Timer | Digispark Attiny85 TINKERCAD
The timer is designed to control line ( C/L ) electric model of the aircraft.
Brushless motor with PWM control unit.
Step 1: Programming
Using Great Cow BASIC
#chip tiny85,8 '8
#config OSC = RC, BODEN = OFF
#config osc = int
#define MOTOR PORTB.0
#define LED PORTB.1
#define SERVO PORTB.2
#define WORK PORTB.4
Dir MOTOR Out 'PB0, pin 5
Dir LED Out 'PB1, pin 6
Dir SERVO Out 'PB2, pin 7
Dir WORK Out 'PB4, pin 3
Dim PWMCounter as Word
Dim MotorSpeed as Word
Dim ServoRotation as Word
Dim FTime as Byte
Dim FMode as Byte
#Define ASize 7
Dim AMotorSpeed(ASize)
Dim AWait(ASize)
Dim interval as byte
AMotorSpeed = 58, 60, 95, 125, 95, 60, 58
AWait = 3, 1, 1, 5, 1, 1, 1 'Load saved flight time
EPRead 0, FTime
EPRead 1, FMode
if MCUSR.1=1 AND FMode=0 Then '
FTime=FTime+1
if FTime>9 Then FTime=1
EPWrite 0, FTime
End If
MCUSR.1=0
FMode=0
EPWrite 1, FMode
FlashLed FTime
Set WORK On
Wait 5000 ms
FMode=255
EPWrite 1, FMode 'Call the initialisation routine
InitMotorControl
ServoRotation = 25 'Main routine
For interval = 1 to ASize 'Hold speed
MotorSpeed = AMotorSpeed(interval)
FlashLed 1
Wait AWait(interval) s
ServoRotation = 125
Wait 1 s
Set WORK Off
Next
FMode=0
EPWrite 1, FMode
MotorSpeed = 0
Do
NOP 'Stop
Loop 'Setup routine
Sub InitMotorControl 'Clear variables
MotorSpeed = 0
ServoRotation = 0
PWMCounter = 0 'Add a handler for the interrupt
On Interrupt Timer0Overflow Call PWMHandler 'Set up the timer using the internal oscillator with a prescaler of 1/2 (Equates to 0)
'Timer 0 starts automatically on a microcontroller, therefore, StartTimer is not required.
InitTimer0 Osc, PS_0_1
SetTimer 0, 0
StartTimer 0
End Sub
'PWM sub
'This will be called when Timer 0 overflows
Sub PWMHandler
If MotorSpeed > PWMCounter Then
Set MOTOR On
Else
Set MOTOR Off
End If
If ServoRotation > PWMCounter Then
Set SERVO On
Else
Set SERVO Off
End If PWMCounter += 1
If PWMCounter = 1250 Then PWMCounter = 0 ' Период 625
End Sub Sub FlashLed( Max )
Dim Speed as byte
Wait 1000 ms
For Speed = 1 to Max
Set LED On
Wait 100 ms
Set LED Off
Wait 400 ms
Next
End Sub'MOTOR ESC 62 - 125
'SERVO 25 - 150Attachments
Step 2: Working
The motor speed will vary from 0 to 15,600 rpm with a programmable time of 1 to 5 minutes.
