Introduction: Control Winamp From Nintendo DS Browser
Here is a quick and easy way to use your Nintendo DS Browser to control Winamp.
*Edit*
-I have updated the skin to version 1.01, which now includes a search page. This search page is similar to the library browser page, but doesn't load your entire library at start.
Step 1: Download and Install Browseamp
First off, I assume you are running Winamp. If not, go grab it.
You will need to get the Browseamp plugin for Winamp. You can use the installer linked from this page, or look for the newest version here or here
Next, install browseamp.
Step 2: Download and Add DS Browser Skin
Download attached ZIP file, which contains the DS Browser skin.
Navigate to your Winamp home directory. Then enter the plugins dir, and finally browseamp.
You should now be faces with a path similar to "C:\Program Files\Winamp\Plugins\Browseamp\".
The Zip contains a folder named "DS Browser Skin". Extract this file into the browseamp directory.
Step 3: Configure Browseamp
Open Winamp, then enter preferences.
Navigate to the Plugins>General Purpose submenu.
Select Browseamp, then Configure.
Start the server on port 80, take note of the displayed ip address under Info.
Now, go to the skins tab, and from the drop down menu, select DS Browser Skin.
Step 4: Connect With Your DS and Have Fun
Ensure that the computer running browseamp has no firewall or similar measure that will block incoming requests. Also, be sure the DS is connecting to the same network this computer resides on.
Enter the previous noted IP address into your DS Browser and connect.
Switch to SSR mode.
The page that loads should be identical to the one shown in this photo.
Enjoy!
