Introduction: Control Ws2812 Neopixel LED STRIP Over Bluetooth Using Arduino Uno
Step 1: Things You Need
FOR THIS INSTRUCTABLES YOU WILL NEED FOLLOWING THINGS.
ARDUINO UNO:
HC05:
get a WS2812 Neopixel LED STRIP
OR
WS2812 LED :
WS2812 LED Ring:
And few more components as
Jumper wires
Resistor 1k 2k
Breadboard etc
Step 2: Circuit
prepare circuit on the breadboard according to the given schmatics in the image & try to use one other power supply for ws2812 instead of running it from Arduino uno because ARDUINO is not able to run ws2812.& Bluetooth at the same time so try to use extra 5v power supply adapter for ws 2812
If you don't have extra power supply then in the code you can decrease the brightness of neopixel led strip to decrease the power consumed by it.
Step 3: Coding Part
Download the code :
And make sure you install adafruit neopixel library is installed .
And in the code setup the data pin of led strip , no of led in led strip & the brightness of the led strip & upload the code to the Arduino.
Step 4: Setup the App and Test It
And send characters from app to hc 05 to control led strip as shown in images.As sending character "r" will turn led strip into red color similarly all functions are given below:-
CHARACTER FUNCTION
"r" red color led strip
"g" green color led strip
"b" blue color led strip
"w" white color led strip
"o" turn off
"a" rainbow animation
"m" mix pattern
So try all these characters & send it & enjoy your led strip light show in your home
