Introduction: Control Your Room Light With Your Mobile
This instructable will show you how to connect your light bulb to your mobile phone, and control it via IR sensor.
You can control any electrical thing at your home after this instructable, if you understand the main concepts.
The hardware you will need for this project are:
1- Arduino.
2- Light bulb with socket.
3- 1 channel Relay, 5V.
4- TSOP4830, IR sensor.
5- wires.
6- remote control mobile app.
Step 1: Make the Circuit
First of all you should connect the circuit elements like show in the picture.
Step 2: Make Relay Circuit
Rely has 3 inputs and the outputs.
One side, the three inputs are:
1- Vcc
2- Gnd
3- Signal, (Pin 13)
The the other side, is the light bulb wire, you cut it ind pull the wire into it
Step 3: The Full Circuit
Sorry for my bad Drawing :3
Step 4: The Sketch: Part 1
First, download the library from here, and import it like in the picture:
Step 5: The Sketch: Part 2
Download this sketch:
and upload it to your arduino, and get your mobile phone.
Open the IR remote app, then open your serial monitor.
Press the button you want it to turn on your light bulb.
Copy the number from the serial monitor.
Step 6: The Sketch: Part 3
Now, download this:
and paste the number you get from the serial monitor, and upload your code.
Now you can control it very easy.
BE CAREFUL FROM ELECTRIC.
