Introduction: Control Your Computer... With a LASER!
This lets you control mouse motion (mouse clicks just added!) with an everyday $1 laser pointer from up to 20 feet away (and way, way further if you have a more powerful laser).
When choosing lasers, however, use caution. If you pick a way overpowered green laser (like one that can burn things and set matches on fire), you may end up damaging the optics on your mouse. All cheapo dollar store laser pointers are perfectly safe - just use caution on any laser you need to wear "lasershades" for.
You can read through the whole Instructable or just use the video below... ENJOY!
Also, if you like this Instructable, please give it a (+) rating and/or comment. Thanks!
NOTE: This Instructable has been updated to include mouse clicking!!! The video has also changed to incorporate this.
Step 1: The Materials
- An optical mouse (I bet your computer already uses one)
- A laser pointer (you can use a cheap $1 laser pointer0.
Step 2: The Setup
Position your mouse by standing it up (leaning against the monitor). This will allow you to control the mouse from anywhere in the room! Make sure the underside of the mouse (the side with the shiny red thingy) is facing the room - not the monitor.
Step 3: AMAZE YOUR FRIENDS!!!
Now for the fun part...
First, identify the sensor on your mouse. It will be recessed and it will look like a tiny bubble tinted black. When you move the mouse on a mouse-pad, the mouse shines a laser below it and this sensor picks up the light and interprets it as movements. So this sensor move based on incoming light... and you have a laser which emits light.
SO, by putting the two together, if you shine the laser so the dot hits the sensor on the mouse, you can control the movement of the mouse!
After you first get a "lock" on the mouse, you no longer have to shine the laser directly at the sensor - just in its vicinity. If you move the laser right, the cursor moves right. It really works and it is really cool.
It might not be *that* useful, but hey, it is FUN!
Step 4: Add Clickability
You only need these parts:
- LDR (about $0.50, available at any electronics store. Also called a Photo Resistor)
- Straw (this will be used to make the barrel for the LDR)
- Electrical Tape (to "insulate" the barrel from light)
Next, go ahead and create the barrel by wrapping the straw in electrical tape. Make sure no light can pass through the side of the straw.
Go ahead and solder the Photo Resistor to the two wires sticking out of the mouse (there is no polarity). When the photo resistor does not contact light, there is a lot of resistance. When it does contact light, there is very little resistance (this simulates a button click).
Lastly, insert the LDR into the barrel and tape it in place.
You're DONE!!!!
To click,shine the laser into the barrel. It's as simple as that!
Step 5: Increasing Movability....
If the cursor is too sensitive, it is easy to fix!
Just follow these images:
Also, if you want to learn more about lasers, go to the laser forum
If you want to buy the laser pointer I used, go to this laser pointer shop.
Posted by Laser Community member: ghost
The Instructables Book Contest
90 Comments
7 years ago on Step 5
how to solve the problem of inversion?
8 years ago on Introduction
VERY GOOD INTELLIGENT WORK WITH HIGH COMMERCIAL POTENTIAL.
MY 100 percent marks , congrats and thanks
dhpmet@gmail.com
10 years ago on Introduction
This is simply wonderful!!!! Great Idea! congrats.
11 years ago on Introduction
GOD JOB. Mac can do something useful
I think I noticed that the mouse movement is inverted in the video. You could probably fix this in the control panel, with a special program, or using a mirror. Also, you could probably use a cheap Fresnel lens to enlarge the beam. Very cool instructable.
This can be drastically and easily improved with the use of a diffraction grating (or you could use a convex lens) placed in front of the laser pointer. You can buy laser pointers with a "star lens" (diffraction grating) that work very well with this. The star lens will spread the laser out into many (hundreds of) points with each able to interact with the mouse. This way you can move the laser without really worrying if your dot is close enough. If you use a convex lens (magnifying glass) it will spread the laser beam out to make a wider beam (but less bright); this method works too, but is not as good as with a diffraction grating. If you want the ability to click you will have to put the photo resistor far enough away from the mouse that it will not move the mouse and click at the same time.
Where to Buy
12 years ago on Introduction
yo you should check out kipkay's channel. you can make a burning laser with that pointer you have!!
wah tak kiro apik mas....ternyata....
14 years ago on Introduction
I have an apple mouse and the clicking part is a button. How do I solder the wire on if I can't find them?
Reply 14 years ago on Introduction
easy, macs suck, therefore it's no possible :P
I think im just going to make a movie...without seeing the BSoD. Care to join me? Oh wait...
Reply 12 years ago on Introduction
You're having BSOD's but i don't :P
You just have a degraded PC , period .
The thing is though , most people use their macs for a short time .
And people use their PC's for very long time
I thought you said Easy Mac, and im like oh Yumm.
Mac's are ok, they just use different "electronics" in their hardware
Unfortunately, I don't have an Apple mouse. Can you post a picture of the insides? Then I can help.....
i started thinking....is it possible to increase the amount of sensors on the mouse? i got this idea when i thought of the wiimote white board, and thought i might be able to control the mouse via 3 or 4 sensors on the monitor, and my green laser pointer would be the tracked point.
13 years ago on Step 4
If you wanted to, could you also hook up another one of these to the right mouse button using the same procedure?
Reply 13 years ago on Introduction
Why couldn't you? The only thing is you would have to keep the photo resistor away from the other one otherwise they would click both the mouse buttons.
I wonder if this could be even made to click the mouse button easier by addind a IR reviever and using a IR LED to click it. ANy way this could work without any other parts needed?
maybe if you put the laser inside and held a mirror you could shine it back onto the mouse but if someone walks into your room their eyes are screwed
