Introduction: Controlling LED S Using Microphones Tutorial
Hi, my name is Leor Oved and today I will teach you how to wire and code my new cool instructable. In this lesson you will learn how to control an LED using a microphone. As you speak in the microphone, the light would turn on and it would turn off if you stop speaking in the microphone.
To begin, follow all the steps provided below.
Feel free to comment.
Good Luck!!
Step 1: Materials
For this project, you will need:
1. An Arduino with a USB cable
2. A Breadboard
3. A Microphone
4. Male Jumper Wires
5. An LED
6. A Brown/Black/Orange/Gold resistor (You can use other resistors but this one is most preferred)
Step 2: Setup
The following shows how to wire your materials together
If the microphone is not working, try to turn it around
If you have any questions please feel free to leave a comment below
Step 3: Code
int led = 13 ; // set point D13 as LED
int microphone = A0; // set point A0 as microphone
int val = 0; // define numeric variables val for microphone
void setup (){Serial.begin(9600); //activate serial monitor
pinMode (led, OUTPUT) ; // define LED as an output
pinMode (microphone, INPUT) ; //define microphone as an input
void loop (){ val = analogRead(microphone); // reading microphone and storing it as val
Serial.println(val); //print val
if (val >= 1){ //if the microphone is receiving soundsdigitalWrite (led, HIGH); //turn LED on
} else { //if the microphone is not receiving soundsdigitalWrite (led, LOW); //turn LED off
