Introduction: Controlling RGB Led Strip With Arduino
Hello guys , in this instructables i have controlled the RGB Led strip using Arduino.The project is quite simple we are using three potentiometers to trigger Red Green & Blue color of the RGB Led strip individually so the idea is really simple by combination of three potentiometers we can glow any particular intensity of any of the three color and as we know we can generate any color by these three Red Green & Blue color so in short by this we can make the RGB LED strip glow in any color and since ARDUINO can not provide enough power to RGB LED strip to glow so i used a IRLZZ4N Mosfet to amplify the signal to provide enough power for RGB LED strip to glow,you can use any equivalent Mosfet/Bjt any high power transistor.
Step 1: Gather Your Components
BUY PARTS :
BUY TIP120:
https://www.utsource.net/itm/p/384328.html
BUY 12V ADAPTER:
https://www.utsource.net/itm/p/8013134.html
BUY ARDUINO UNO:
https://www.utsource.net/itm/p/7199843.html
so the basic components we need are :-
a Arduino
One 5m RGB Led strip
Mosfet irlzz4n or any equivalent or TIP 120 bjt or equivalent
3 potentiometer
Affiliate Buying Link :-
RGB Led strip :-
https://www.banggood.com/Wholesale-24-Key-IR-Contr...
https://www.banggood.com/5M-RGB-Non-Waterproof-300...
https://www.banggood.com/5M-SMD5050-Waterproof-RGB...
Potentiometer :-
https://www.banggood.com/10Pcs-Double-Potentiomete...
https://www.banggood.com/2-PCS-Lantian-10K-Rotary-...
https://www.banggood.com/5Pcs-Adjustable-Potentiom...
Arduino Uno:-
https://www.banggood.com/Wholesale-Arduino-Compati...
https://www.banggood.com/3Pcs-Arduino-Compatible-R...
https://www.banggood.com/UNO-R3-ATmega16U2-AVR-Mod...
l?p=LU070313923481201709
MOSFET'S - https://www.banggood.com/10Pcs-IRFZ44N-Transistor...
Darlington TIP 120-
Step 2: Circuit Connection
connect all the circuit according to the given schmatics.
Step 3: Programming
The code is really simple.Upload the code shown in the image.
Step 4: Test It
so finally it is done , now varry any of 3 potentiometer to varry any of 3 (red,blue,green) color intensityand if have any issue refer video.
