Controlling an LED With Arduino and Wifly Shield
Intro: Controlling an LED With Arduino and Wifly Shield
To demonstrate how you can control devices via wifi using the arduino wifly shield, I will switch on and off an LED by sending a http request from my web browser to the wifly shield.
Requirements:
1. Arduino uno
2. Wifly shield
3. Led
4. 220ohm Resistor
5. A couple of jumper wires
The set up is as shown in the picture above.
STEP 1: Implementation
After setting up, it is time for you to upload the code. There are two ways you can go about it.
1. Use the wifly shield as a wifi hotspot
2. Join an existing wifi network using the wifly shield
STEP 2: 1. Use the Wifly Shield As a Wifi Hotspot
In this case you need to configure the wifly shield as a hotspot then upload the code i have attached here.
STEP 3: 2. Join an Existing Wifi Network Using the Wifly Shield
Here you will set the wifly shield to join a wifi hotspot using the serial monitor, or code. After setting the wifly shield using the serial monitor, upload the same code that you used when using the wifly shield as a hotspot (the previous above).
Instead of using the serial monitor to join to the wifly shield to a wifi hotspot, you can use code. To do so, upload the sketch below.
STEP 4: Controlling the LED
After uploading the code, open the serial monitor and wait for the wifly shield to start its own hotspot or connect to the hotspot you have specified. The serial monitor will show you the ip address of the wifli shield.
Connect your computer or smartphone to the wifi hotspot your wifly shield is connected to, and enter on your web browser the WiFly shield IP address displayed on the serial monitor followed by /$1# (to switch LED off) or /$2# (to switch led on). So, in my case its 192.168.43.89/$1# and 192.168.43.89/$2# respectively.
STEP 5:
If you have used the WiFly shield to create a wifi hotspot, you will have to change the IP address of your computer’s Wifi adapter. Steps on how to do that are described in this link.
In my case I changed mine to 192.168.1.1 since my wifly shield’s IP address was 192.168.1.0.
Then switch on and off the LED the same way you did above, replacing the IP address with the one displayed on the serial monitor.
STEP 6:
Now you will be able to control an LED with arduino and a wifly shield. Apart from switching on an LED, you can also control bigger devices using a relay. Therefore, think of some cool things you can do with this and try them out.
4 Comments
Frostsmaker 6 years ago
Will it turn on everything that connected to arduino? If yes, how to turn on only one LED which is connected on let's say pin 7 and let the other pin to turn off.
ZhenhuaC 6 years ago
good
DaleH52 7 years ago
Danger is my middle name 9 years ago
Very helpful!
