Introduction: Controlling Speed Controllers With Arduino.
Hey guys, I'm back with another instructable. This is about RC speed controllers. What this will do is allow you to test out your speed controller in the Arduino world using Serial, then you write the values down and can use them for your projects.
Submitted by Newton Labs for the Instructables Sponsorship Program
Step 1: Setup
All you need to do is hook up your speed controller to your Arduino, red(s)->+5 black/brown(s)->GND yellow/white(s)->10 and/or 9.
Step 2: Programming
// If you need any help feel free to PM me (simonfrfr) or email me
// at newtonlabs@bellsouth.net
String readString;
#include <Servo.h>
Servo myservo; // create servo object to control a servo
Servo myservo2; // create second servo object
const int left = 10; // left motor's pin on arduino
const int right = 9; // right motor's pin on arduino
void setup() {
Serial.begin(9600);
Serial.println("servo-test-22-dual-input"); // so I can keep track of what is loaded
void loop() {
while (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
readString += c; //makes the string readString
delay(2); //slow looping to allow buffer to fill with next character
if (readString.length() >0) {
Serial.println(readString); //so you can see the captured string
if (readString == "l") // acfivates left servo only
myservo.attach(left); // writing both to left motor
myservo2.attach(left);
if (readString == "r") // activates right servo only
myservo.attach(right); // writing both to left motor
myservo2.attach(right);
if (readString == "b") // activates both motors
myservo.attach(left); // writing to left motor
myservo2.attach(right); // writing to right motor
int n = readString.toInt(); //convert readString into a number
// auto select appropriate value, copied from someone elses code.
if(n >= 500)
Serial.print("writing Microseconds: "); // serial display
Serial.println(n); // number
myservo.writeMicroseconds(n); // writes to ports
myservo2.writeMicroseconds(n);
else
Serial.print("writing Angle: "); // serial display
myservo.write(n); // writes to ports
myservo2.write(n);
readString=""; //empty for next input
String readString;
#include <Servo.h>
void setup() {
Serial.begin(9600);
void loop() {
if(n >= 500)
else
myservo2.write(n);
Step 3: Enjoy!!!
Go to Serial monitor and input number values and you can try different frequencies for different RC speed controller rates. Enjoy! Feel free to ask any questions or comment on my coding.
