Introduction: Convert Towerpro MG995 Servo to Continuous Rotation
Do you need some relatively powerful and very cheap servos for continuous rotation? Well, here I will tell you how to go about converting the Towerpro MG995 servo (rumoured to be 10kg/cm Torque) to continuous rotation.
Any constructive advice on the project or on the instructable would be appreciated - this is my first so be gentle :)
Step 1: Items Required
To start with, you need some Towerpro MG995 servos to convert.
I purchased 2 with metal gears here http://www.dealextreme.com/p/towerpro-mg995-metal-servo-with-gears-and-parts-10kg-torque-20089
2 each of 2.2 k Ohm resistors per servo motor. (Optionally a 5 k Ohm pot... or even the one in the servo. More about this later)
Then you need a soldering station and solder.
Helping hands help.
Wire cutters.
Small Phillips screwdriver.
Small awl (not pictured in tools photos)
Dremel and cutting disk
Goggles for safety of course.
Some means of testing and driving the servos. I used an arduino perfboard clone, a breadboard and some batteries.
Step 2: Open the Servo
To start we need to open the servo.
Use your small phillips screwdriver to unscrew the 4 screws from the back of the servo.
Remove the back of the servo case.
Remove the front of the servo case.
You will then have exposed the gears and the circuit board.
Step 3: Remove the Gears, Motor and Circuit Board
Extract the motor, circuit board and gears from the servo body.
Take note of the order in which the gears are mounted, but if you are doing this then you are probably quite capable of determining their positions when putting it all back together by how they fit.
Cut the wires running from the circuit board to the 5kOhm pot
Step 4: Remove the 5kOhm Pot
The 5kOhm pot is not a continuous rotation pot and because the drive gear is mounted on it, this will prevent the druve gear from rotating 360 degrees.
So we need to remove it.
Looking at the photos you can see there is a small screw and some clear glue holding the pot in place.
Unscrew the screw and scratch out the glue - I used an awl included in my screwdriver set.
Finally remove the pot from the servo body and put it aside for use in another project.
Step 5: Remove Protrusion Preventing 360 Rotation
In addition to the pot itself not rotating 360 degrees and therefore preventing continuous rotation of the drive gear, there is also a protrusion which will also prevent rotation. This protrusion needs to be removed.
Here you need to use your goggles to protect your eyes. Don't be stupid and try do it without. Your eyes are way too valuable and you are not invincible - even if you think you are.
I placed some serviette in order to keep the metal particles away from the rest of the gears.
I held the hears in my hand but in retrospect it may be better to leave the pot in to prevent the gear rotating fully while you are removing the protrusion.
Be sure to wear your goggles and ensure the side of the cutting disk you are using is rotating away from you so any sparks are thrown away from you. Take your time.
Step 6: Add Resistors
We now need to add the resistors which will act as a voltage splitter and allow the servo to be controlled.
Remove the remains of the wires from the circuit board.
bend the resistor leads as shown in the photos and solder as indicated.
cut off the excess leads.
solder the legs of your resistor voltage splitter to the circuit board as shown. Note the middle pin is the reference voltage and runs to the join between the two resistors.
Step 7: Test the Motor for Continuous Rotation
Before putting the servo back together we need to test the motor and servo to ensure we can control it.
I used an arduino clone to test the servo.
Ideally sending a servo.write(90) should hold the motor still. In my case this did not happen.
This is why it might be useful to solder in a 5k pot instead, send a command to 90 degrees and then turn the pot until the motor does not turn any more. Then glue the pot position with some hot glue.
Since I had the resistors I needed to determine where the centre point of my servo was. I wrote a simple arduino sketch to read an angle input in the serial monitor and to write this angle to the servo. Doing this I found for the two servos I converted the centre point angle was 104 and 106 degrees respectively. Sending an angle greater than this will cause the servo to rotate in one direction, and an angle less than that would cause the servo to rotate the other direction.
Unfortunately I have scrapped the script.. so I cannot post it. Never-mind, I am sure you are capable of writing such a script yourself.
Speed control is in terms of the size of the difference between the centre point and the angle you have written.
So, for my servo with 106 degrees as the centre point 126 degrees would turn slower than 136 degrees but both would be in the same direction.
86 degrees would turn the servo at the same speed as 120 degrees, but in the opposite direction.
Step 8: Put It All Back Together
Final step is to put it all back together.
Put the gears back in place.
Turn the gears by hand to ensure everything rotates smoothly.
Insert the motor and circuit board back into the servo body.
put the front and back covers back on.
Screw it all back together.
Test it again using your script as explained in the previous step.
Step 9: Thoughts and Conclusions - Credit Where Credit Is Due
These tower pro servos are cheap - not only in their cost but also their construction - you get what you pay for.
I certainly would not use them for important tasks, but as a continuous rotation motor with adequate torque they are fine.
I do find the zero point angle of my servos seems to change from time to time. Probably because of static electricity and maybe even humidity and temperature. Using a pot which was mounted on the body and accessible from the outside would be useful to fine tune the servo centre point when in use.
Credits
I used these instructions as a guide - thanks dude wherever you are. http://www.laureanno.com/RC/servo-rotate.htm
My battery holders you saw were printed on my reprap printer using a design by obijan - see http://www.thingiverse.com/thing:5079
And the caterpillar tracks design by Olalla see http://www.thingiverse.com/thing:8559
Further information about the bot itself will be posted on Lets Make Robots - link to be provided when the info has been published.
If you are looking for an interesting and challenging project you could consider building a reprap 3D printer - see http://www.reprap.org
1 Person Made This Project!
- osdoyi made it!
10 Comments
4 years ago
Thanks! This was big help in my useless machine project ;)
5 years ago on Step 5
You don't need to grind the rotation stop peg away, it can be pulled out with a good pair of side cutters (pliers slip off, but side cutters can extract it). Same with the pot, it can be set to 'centre' and palcked inside the case along with the peg taped up in case you wish to return the servo to nprmal function. Good pics, very helpful :-)
6 years ago on Introduction
Bought a couple of these and tested with a standard Arduino "Knob" test, and they were continuous rotation right out of the bag. Damn, that's not what I wanted.
One of them goes continuous in either direction when the pot (see "Knob" sketch) is turned. The other motor goes one direction and if the knob is turned too fast, it doesn't change direction, it just keeps turning the original direction.
Not really a good purchase.
6 years ago on Step 7
Hi, great instructable! I was able to follow all steps without problems. One thing though: The metal pin that keeps the output-gear from rotating all the way can simply be pulled out of the gear with minimal force (at least the one in my test-servo). I just grabbed it with a wirecutter while keeping the gear steady with a pair of pliers. Beats grinding it down and you have a shiny new pin to play with...
9 years ago on Introduction
Hello, thanks for the instructable, I just want to know how many RPM it arrives, and how much torque it has, approximately, so I can see if it suit my project.
Hi Franco
I am not sure about the torque, but it certainly delivers enough for my requirements. I used these servos to drive a tracked robot with the tracks printed on my Mendel reprap. These servos deliver enough torque to allow my robot to turn on a carpet, which many builders will tell you is a difficult thing to achieve given the friction created.
The link states they deliver torque up to 10kg. They are cheap so you could simply buy one or two and test them.
As for RPM - I think I get between 40 and 50 rpm.
Regards
You can remove the hardened metal pin with a pair of side cutters - not to cut it off, but to grip it and pull like a tooth. Worked for me. On my 10Kg MG towerpro I was able to lift out the pot, leave it in the middle of it's travel and still fit everything back in again. I taped the pin to the pot wires in case I ever need to make a servo out of it again.
Good luck.
Gareth
Hi Gareth
I did try pulling the retaining pin out with a pair of pliers but just could not manage that. I found it was too tightly rammed in.
Great idea about extracting the pot but not removing it... Much simpler than soldering in the resistors. If I need to do some again I certainly will give that a try.
Pliers will slip off, but with care side cutters will grip it enough to lever it out if you use the tip of the clippers as the pivot point, load is pin in middle of jaws, handles for the lever. I think that makes sense :-)
I've done similar to this, with the lower-grade servos, mainly Futabas, for robot projects.. I replaced a pair of constant-rotation servos on a Parallax BOE-BOT frame, with Futaba 3004's, simply by clipping, and filing down the stop-point on the drive gear, and folding the pins for the potentiometers so the post end would poke out the side. (then simply careful twisting the post to center it.) I imagine these, though would hold up a lot stronger, with the metal gears.
