Introduction: Convert a MR16 Fitting to GU10 Fitting!
Before you start you will need:
- Switch of the power at the fuse box.
- GU10 lamp box.
- Electrician's screwdriver or small flat head screwdriver.
Remove the fitting and transformer from the ceiling by pulling firmly.
Step 1:
Disconnect the mains feed going INTO the transformer from the lighting circuit.
Step 2:
Leave the cable going FROM the transformer to the fitting.
Step 3:
Uncover the connector block on the fitting (ours is screwed some are clipped) to expose the connector block inside.
Step 4:
Unscrew the cable connecting the transformer to the fitting.
Discard the transformer.
Step 5:
Disconnect the MR16 lamp holder from the connector block and discard.
Step 6:
Connect the GU10 lamp holder to the connector block, feeding through the inside of the fitting with the lamp holder inside.
Step 7:
Connect the mains cable directly to the fitting and re- cover the connector block.
Step 8:
Install GU10 LED bulb – from www.homewatt.co.uk of course.
Step 9:
Re-install fitting into ceiling and switch electricity back on.
Step 10:
Let there be light!
