Introduction: Convert Your Bluetooth Headset Into Wired Bluetooth Headset
Today i'm going to tell you how to make or convert your own wired bluetooth headset.
Follow my step and your are some step behind to convert it.
Step 1: We Need
Our Requirements are as follows:-
1.Scissor
2. Some Tape
3. Screw Driver
4. Mobile
5. Soldering Iron and Soldering Stand
6. Soldering Paste And Solder
7. Lighter
8. Blade
9. Bluetooth Headset
10. Old EarPhone
Step 2: Procedure With Earphone
First we take an old earphone and cut it into half.
Now take the part which contain speakers and burn your lighter on the cut end point then solder each wires with the help of soldering components.
Now solder two wire together. here question come which wire to chose.
Ans:- Solder both golden wires together and solder both other colored wire together.
Step 3: Procedure With Bluetooth Headset
Now open you bluetooth headset carefully. Place all the small components on other side. KEEP IT SAFE.
Check which wires are connected for speaker then unsolder those wires from circuit and paste it on the body of bluetooth headset with the help of some tape.
Now take the earphone golden wire and solder it on -ve sign and solder another wires to +ve sign.
Test it with you phone which is compatible with it or you can test it on your laptop.
Step 4: Assembling
Now Assemble all the parts of bluetooth headset.
And test it again......
Step 5: Demo
Enjoy my friends.....
And don't forget to Share and vote me if you like it..
Thanks foe seeing it..
Step 6: Upgrades
1st Upgrade is at
https://www.instructables.com/id/Upgrade-Your-Bluet...
2nd Upgrade is at
Enjoy.......
