Introduction: Convert Your Relector Into a Bike Light!
What you'll need
- A bike reflector bracket
- Something that can slide into the grove where the reflect goes (Popsicle stick or whatever you have lying around will do)
- A cable tie or a rubber band
- You might need a longer bolt
- And a flashlight of your choosing
Step 1: The Bracket
This is the bracket I used, it's the kind that the reflector slides into. Discard the reflector (Keep it if you live in a place where they are required by law, such as the UK) . Find something that will snugly slide into the slot the reflector was held in. I used an extra divider from my tackle box, but I suspect a wide Popsicle stick or any number of things can substitute, it just needs to be long enough to cable tie, rubber band, or tie, your flashlight to, as you'll see in the next step.
Chances are your not going to find something the prefect size for the slot, so you might have to trim whatever it is your using down a little
Step 2: Attaching the Flash Light
Its pretty straight forward, cable tie the light on. Use a rubber band, some twine, glue, whatever you got.
Step 3: Mount It Here
The perfect place to mount your new light is just under the handlebars where it cant get in the way and clutter up your hand space. The bolt that came with the bracket will likely be too small to close around the stem but dig into your old bucket of nuts and bolts and you'll undoubtedly find one long enough.
Step 4: Your Done!
Enjoy riding safer as it gets darker.
Summer #mikehacks Contest
3 Discussions
6 years ago on Introduction
Great idea! I have a coupla brackets like... Anything that helps you be seen is so important in these days of distracted drivers.
6 years ago
Just a wee note for UK readers. In the UK, it's a legal requirement for a bike to have front and rear reflectors, as well as lights
Reply 6 years ago on Introduction
Thanks for pointing that out, I was unaware.
