Introduction: Converting Hydraulic Cylinders to Pneumatic
in this instructable I will show you how I converted 3 AMC hydraulic cylinders to pneumatic
2 of them worked, 1 failed, badly
Step 1: Flushing the Oil Out
now you can't just plug a hydraulic cylinder into a air source, it would contaminate the rest of the system
my hydraulic cylinders where from a small injection moulding machine and are made of stainless steel
because mine are made of stainless steel they won't rust internally if flushed out with water, using a screwdriver push the tube cap off and remove the rubber seal so it looks like the top image
Step 2: Tubing
after the cylinders have dried out take some clean, dry tubing and using the parts in the cap of the cylinder your going to want to put them on like in the picture
Step 3: Putting the Tubing Back in the Holder
then you measure the depth of the holder and use it to compare against the hight of your cap and tube to work out what it needs to be
then you just push the assembly into the holder and there should be a click and then it's airtight and the cylinder is ready to be used
