Introduction: Bypass Your Broken Airport Express PSU With an USB Power Source
Ever have an Airport Express (AE) that will not power up anymore? Most likely it is from a broken power supply unit. The cause is usually from a bad 3.3v regulator and/or bad capacitors. This guide will show you how to bypass Airport Express PSU and power it with USB power. This will great if you want to use an 5v USB A/C adapter, power it off your computer, or use any other USB power source.
Here is a list of suggested tools and materials you might need:
Airport Express
Hand Saw
Multimeter
Soldering Iron, Solder
USB cable
USB Compact Flash card reader, $2 online (slightly smaller than the AE so it fits inside)
3 wires (2-3inch in length), one for ground, one for 5v and one for 3.3v.
Update: I changed the blue tape to white tape on the reassembly of the housing.
Step 1: How to Open the Airport Express Case
Use the hand saw and cut along the case seam of the Airport Express. The seam is where the two pieces of the case is joined together. The depth you need to saw is 1/8 of an inch. You should stop right when the plastic breaks through and you can see the insides. Go slowly as you do not want to damage anything inside.
Step 2: Disconnect the Power Cable
Once open, disconnect the power cable from the power supply. There should be three ground wires (black), one 5v wire (red), and two 3.3v wires (orange).
Step 3: Test the CF Memory Card Reader
Use your multimeter and find the locations of the ground, 5v and 3.3v on your CF Memory Card reader. I am using the CF memory card reader for two reasons. One, it provides me with an existing USB port. And, two, a CF card reader provides a 3.3v output. AE runs on both 5v and 3.3v. You can create your own 3.3v stepdown if you want.
You can use your multimeter and test your power supply too. A word of warning, there is a risk of electric shock if you do decide to tinker with your broken AE power supply.
Step 4: Wiring
Disconnect the power cable from the AE. Snipe off the connector that plugs into the power supply end, not the end that plugs into the actual the AE. Twist the ends of each type of wire together so it forms one tip. Extend the length of the ground, 5v and 3.3v wires by soldering the 3 inch wires. You can pick your own colors, but ground is usually black, and power is usually red.
Step 5: Soldering Wires to CF Card Reader
Solder the ground wire to the ground spot on the CF memory card reader. Solder the 5v wire to the 5v spot on the CF memory card reader. Solder the 3.3v wire to the 3.3v spot on the CF memory card reader. You can test the CF card reader to see if the wires are carrying power.
Step 6: Testing the USB Power
Plug the power cable back into the AE. The other end of the power cable should be soldered into the CF memory card reader now. Power up the USB CF memory card reader. If everything went properly, the AE should light up. You can run the Airport Utility to see if the AE is operational.
Step 7: Reassembling the Airport Express
Now just reassemble the AE. I suggested 3 inches of wiring because you might need to twist the wires so everything fits correctly. I positioned the USB port so its in the same spot old power cord opening. Your reassembly might be different depending on how you soldered or the size of your CF memory card reader.
Step 8: Final Thoughts
Use white tape electrical tape along the seam to make the reassembly look cleaner. You might also want to glue the case.
Standard USB power outputs 500mA. AE runs on 3.3v @ 1.3A and 5v @ .7A. You could want to try higher mA source if you plan to run both the AE audio jack and AE usb port.
Shout Outs/Thanks:
Chris for some of the materials.
http://weistudio.com for inspiration.
33 Comments
Tip 4 years ago on Step 4
For the new version A1264 with blue board 820-2407-A and only 6 black wires:
There is no 5 V, 3 wires for GND and 3 for the 3.3 v BUT they are inverted, see the picture !
Reply 8 months ago
This is a helpful post for those with the newer board revision with six black wires. I was able to make my unit turn on by feeding 5v to the right three wires, but nothing happened with 3.3v. However, the unit doesn’t want to fully start up, the light is yellow for a while, then it turns green for just a second then seems to start the boot process over again. Makes me wonder if one of those three right hand wires needs 3.3v and others need 5v.
Reply 3 years ago
I also have the version with six black wires. I followed the Mad Chat’s wiring advice and used a $3 buck converter from eBay set to 3.3v and a 12v 2a plug in power supply from McMaster-Carr (70235K19) and am back in business!
3 years ago
Can I just go with 5v? What's the 3.3 for? Audio?
6 years ago
Just to note I tried this and it didn't work with the CF reader I had.
I had the 'N' version of the Airport Express which was fully working, and checking the power it only required +3.3v.
I found the +3.3v on the CF reader (either the card detect pin, of off of on side of an LED, which stayed at 3.3v until I plugged into the airport express.
Once plugged in it dropped drown to 0.5v, so I'm guessing that the CF reader can't cope with the power that the airport express if drawing :-(.
Tried with the a 1amp USB and off the laptop
7 years ago
For the newer APEs with 6 black wires, check out the following image.
https://dl.dropboxusercontent.com/u/2188600/APE_Wires.jpg
7 years ago
Hello,
why not repair the original power supply?
1) If the fuse is blown even change the ic DM0265R under the sink and the two capacitors 10uf 400Volt.
2) if it still not working replace any 100uf 10V capacitors that are burned (look under the white glue).
good luck
7 years ago on Introduction
Hi everyone.
Tried to use this : Wingonneer USB to TTL Converter Module with Built-in CP2102
http://www.amazon.fr/gp/product/B00AFRXKFU?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
The only thing I get is the green light flashing once, and then nothing.
Does anyone have an idea on haw to fix it, if ever possible ?
Many thanks in advance !
cheers! thanks for sharing, I've used this instruction a bit as a reference repairing a broken Apple Airport Express A1264 54 Mbps Wireless N Router (MB321LL/A). It all started with accidental reboots of the router and then it would just power on, but won't even boot. I fixed it by opening it up with a knife instead of a saw - I just cracked the internal lockers, but the gap between two parts turned out to be way smaller then it would have been if I'd saw cut it through. Then I looked at the power supply half and found a capacitor that heated too much and even left some marks on a PCB. It was somewhere around 10V 100 uF 105 ˚C and that was clearly not good enough, so I replaced it with a 16V 100 uF 105 ˚C capacitor and actually assembled the unit back. Works just fine for a month or so already.
What specific CF card reader and why not one of these?
http://www.amazon.com/6-5-12V-MB102-Breadboard-Supply-Module/dp/B00O9YSSUM/ref=sr_1_18?ie=UTF8&qid=1439013860&sr=8-18&keywords=Power+Supply+USB+-+5V%2F3.3V
or
http://www.petervis.com/Raspberry_PI/Breadboard_Power_Supply/YwRobot_Breadboard_Power_Supply.html
I'm doing this with a fully functional AEX first generation N (blue board) The power lines between the two boards are all black, but the first 3 are ground, the last 3 are 3.3V. So while the form factor of the first generation N is the same as the one above, the circuitry is much more aligned with the latest 2nd Gen AE (white AppleTV) with on board audio as opposed to snap chip.
8 years ago on Introduction
Just in the process of taking my Airport Express apart too. First off my unit appears to be a slightly different revision than the above. First all the wires are black, ok, looking closely at the circuit board there is 3.3v on one side and GND on the other. Easy the side with 3.3v must be 3.3v. I pulled out the multimeter and dialed it to the continuity indicator, hmm, the 3.3v has continuity with the shielding. So I pulled out an old usb cable stripped it down to test if the 3.3v side has continuity with the black usb wire, yep, what about the usb shielding, yep. Crap that must be GND. Ok so the first wire is GND, which other wires have continuity with the first wire, the next to wires beep, so the the three wires from the 3.3v label are GND. No I start from the other side, the next two wires have continuity with that side. Well crap, there basically only two leads and one of them is almost certainly ground. So is there a short in there or is there only one positive lead? Is that lead 5v or 3.3v. The label on the circuit board says 3.3v so that would seem the safe bet, but the USB port needs 5v, and a DC booster would likely need a capacitor large enough to stick out of the shielding, where as a 5v to 3.3v voltage regulator could fit discretely on the circuit board.
8 years ago on Step 8
Thanks for the research and writeup - Since I have no card reader with 3.3v output I have just added two a LM1117 IC to a 5V wall mount adapter to get both voltages.
However: the airport express wants a lot of power. I think at least a 1A 5V adapter is a must (but everyone with a RapsberryPi around probably has one of those)
9 years ago on Step 5
What CF Card Reader did you use? and for some reason all 6 wires of mine are black.
You ever figure out what the black wires voltage output where? I'm in the same boat.
Same for me : all 6 wires are black, have you sorted it out ?
10 years ago on Step 4
Hey man, regarding the power cable from the AE. I had a speed bump! I think mine is most prolly second gen or just from a different batch. The power cable is all black. :\ Help?
10 years ago on Introduction
Hi,
I just made the fix, and it seems that I need some help... I have locate the ground, 5v and 3.3v on my CF Memory Card reader, wire them, plug the power cable back into the AE and Power up the USB CF memory card reader. Eureka; the AE light up in green! But that's all... My AE is not visible on the wifi network... :( So i recheck my wires with my multimeter, and then i see the 3.3v was no longer on 3.3v but on 1v! So I unsolder this wire, check an another time the 1v on the CF Memory Card reader and mesure 3.3v... In conclusion the 3.3V drop to 1v when i wire it on my AE. May this explain the fact that the AE does not work? How to explain and remedy the voltage drop? I really need to fix my AE... Thank you in advance for your help.
try this first: when your AE lights up, hold the reset button to force the AE to reboot until your airport utility on your computer detects it. if your AE works, then you should be able to configure it.
the voltage might drop since theres a load now. good luck.
I have tried it, but the AE don't reboot. The led stay green, and nothing happen. :(
