Converting a Push Mower to Electric $50
30,499
33
15
Introduction: Converting a Push Mower to Electric $50
The original idea was simple, use a dying electric scooter to power a push mower and take some of the work out of trimming my postage stamp yard. It did not work out as intended, things always seem easier of paper. But, since I have managed to make every mistake possible, please benefit from my mistakes!
Step 1: The Plan
Original plan:
Any 24V scooter has two 12V batteries, a motor and a speed control. Why not pull out the parts and attach it to a push mower to make a variable speed cutter that can be push around the yard. It seemed simple enough.
The motor is way to fast, and finding a simple way to connect the drive belt to the mower did not work for me. The mower runs at about 80 rotations of the cutter for every one of the wheel (WAG estimate). Adding the scooter motor would shoot that high enough to make the mower take-off. Unsafe and unwise.
Adapted plan:
Use a windshield wiper motor (12V) and one scooter battery (using the other as a spare) to power the motor.
Simple and cheap...except that the windshield wiper motor why strong is about half the speed you will need. It cuts, but the process of trimming even a 10' X 12' lawn becomes a chore.
Adapted-Adapted plan:
After destroying the batteries by accidentally overcharging them, I found a powered window motor for $12 online. The RPMs were roughly double, and I could always order the other rotation is I completely ruined one side of the motor.
What a plan! Through a little tinkering, this works very well, and cuts just a little slower than I would like.
Step 2: Acquire Materials
Materials:
mower (mine was $5 on Craigslist)
12V battery (I had to use an alarm battery from Radioshack for $30. A doner scooter would be better)
12V power windows motor 150RPMs or better ($14.99)
4" wheel
Wire and battery connectors
4" angle brackets
10-24 tap kit
1/2 and 1-1/2" 10-24 screws
steel spacer the diameter of your mower shaft
bolt and nuts for your new wheel
steel strapping and pop rivets for battery case
1" rubber spacer
Tools:
Drill
pliers
angle grinder
Step 3: Cut Down the Shafts of the Motor and Mower
The motor shaft and mower shaft will be too long using this setup. With my mower, the gear that drives the shaft is attached with a square key through a hole in the shaft. Since I can't drill a perfectly straight hole to save my life, I decided to utilize this slot in the shaft to connect the motor and the mower.
Use an angle grinder or hacksaw to trim the shaft of the mower about 1/8" to 1/4" longer than the slot location, and trim the motor until it is nearly parallel with the side of the mower when touching the shaft. In my case approximately 1" from the side of the mower hence the rubber spacer.
Use the steel spacer as a guide. One side will need to extend beyond the slot, and the other will need enough room to hold onto the motor. As the two shafts are different diameters, half-lapping them isn't the best of ideas (not that I tried that too or anything)
Step 4: Drill and Tap the Spacer
The steel spacer will need five holes drilled in it. Three in a 120 degree angular layout on the motor side, and a straight hole through both sides on the other to hold the spacer onto the shaft through the slot in it.
The mower shaft hole will need to be fairly straight, but the other three don't need to be perfect. The three will combine to hold the motor shaft tightly, so the exact layout is not that important.
Tap all of the holes for the screws you will use to hold both ends. I like 10-24, but anything could be used.
Setup the spacer(now coupler) on the shafts and tighten the screws. Spin the blades by hand to see if the motor spins. There is some slop built in (at least on mine) so the spinning motor looks more line a cam.
Step 5: Run the Wires, Build the Battery Case and Attached the Wheel
Running the wires is fairly simple. I chose to run the wires through the frame of the mower. They could just as easily be attached to the outside with some zip ties, but it was simple enough to route them through. Only one hole (at the bottom) needed to be drilled.
Building the battery case just takes a little elbow grease. I used welding pliers left over from another project. These have flat wide jaws. Channel locks, pliers, a vise, or even just the corner of work bench should do the job. Don't bend it exactly the size you need, give a little room all the way around. For my case, I used two of the 24" steel straps. The setup was two "J's" and one "O" joining them at the top. I added a side bend for the switch.
The steel is thin enough you shouldn't need a hammer. You can see my "90's" are exact, but the whole case seems to work well enough. I used pop-rivets, but screws and nuts would work better and not leave the mushrooms inside the case. I just had time handy. Test fit the battery, then attach it to the frame.
The reason I waited to mount the wheel until now is the motor may rub against it (as it originally did with mine). You will have to move the wheel forward keeping the blade at more or less the same height.
The remaining sheet metal that formerly surrounded the wheel isn't quite strong enough to support the weight. Use the left over strap or part of an angle bracket to hold the wheel securely.
Step 6: Mount the Motor and Rev It Up
You can see in the picture below I used angle brackets and a zip tie to hold the motor in place. This was meant to be a temporary fix, but it allows enough flexibility and security that I think I will leave it.
Make you battery connects and remember the gear from the other wheel (non-drive side). If you forget, your forward speed will dictated by the speed of the motor. On my mower, that means a slow walking pace. Probably fast enough.
The motor has quite a bit of torque, but the blades can get bogged down when the grass is tall. I wear heavy boots and kick the top blade to start it rotating when it gets into trouble. This is a stupid idea! Just remember that the motor will continue to spin so long as their is power to it. Strongly consider using a momentary push button switch instead of a toggle switch so power is only delivered while you are holding down the switch.
The mower probably isn't powerful enough cut off a finger or toe, but it will give you a raspberry you won't soon forget. Please be careful!
Be the First to Share
    • Jewelry Challenge
      Jewelry Challenge
    • One Board Contest
      One Board Contest
    • Fix It Speed Challenge
    15 Comments
    marcinsusel
    marcinsusel
    4 years ago
    Was just thinking about making this. I have a spare 36V cordless string trimmer that Im going to get the motor and the battery connector out. Im hoping if this works, it will complement all other B&D tools I have.
    You gotta admit that them things is for them hards working people...unlike us lazy nerds we find ways to cheat and add motors to out hand tools...THE YOUTH NOWADAYS! LOL
    sleighbedguy
    sleighbedguy
    Reply 13 years ago on Introduction
    You know, that comment would probably pull more weight if you added a motor to it...
    Odin49
    Odin49
    13 years ago on Step 5
    I like your idea but not able to get the whole picture. Photos from the other side would help.
    sleighbedguy
    sleighbedguy
    Reply 13 years ago on Step 5
    The other side is the stock wheel assembly that came on the mower. The drive gear is still attached, and technically the mower will work without the motor running. If you need more info, let me know and I'll get you a picture.
    aeromancy
    aeromancy
    Very nice idea! This looks like it would save you a lot of money on gas, and give your lawn a nice look. Once again, Great idea! 5/5 stars
    John Smith
    John Smith
    14 years ago on Introduction
    Very cool, but from the video, it seems like a screaming metal mower of doom, but I guess that doesn't matter if it makes a job easier.
    sleighbedguy
    sleighbedguy
    Reply 14 years ago on Introduction
    That is what push mowers sound like. It is simply more continuous. It is actually really quiet. I can't get YouTube to take the second video of the mower cutting.
