Introduction: Conveyor Belt Marble Loop
I love the airport, and it's not even because of the planes (no offence to pilots). It's because of the countless conveyor belts they have there. Check in your bags? Conveyor belt. Need to get to your lounge fast? Conveyor belt. The best one of all is when you go to pick up your baggage. How they manage to make a round conveyor belt is beyond me. With that aside, I've decided to make a simple marble run with a rubber band "conveyor belt" that carries marble up and lets them roll down, and repeats it over and over, and is quite fun to watch. (This seems like a easy enough project that could be done in a classroom setting!)
Let's get started!
This project takes about an hour to build. You'll need:
- Cardboard
- A hot glue gun
- Straws
- A ruler
- A LEGO power functions motor (optional)
- Lego tape (goes with the above mentioned motor)
- Rubber bands, preferable thicker ones
- Hardboard
- A scroll saw
- Miscellaneous marble run building stuff
Step 1: Base Part 1
Step 2: Axles
Step 3: Base Part 2
Step 4: Scoops
Build a shape like this out of cardboard. The thickness should be a little less than the diameter of your marbles. Glue this shape to the Conveyor belt. The number of scoops is up to you! For a relatively slower pace, I've decided to use 2.
Step 5: Motor (Optional)
Step 6: Slope
Step 7: Power Plant
- A spot for the conveyor belt
- A spot for the battery box
- A spot for the motor
I've mounted the motor onto the cardboard with LEGO tape to avoid getting hot glue into the holes, but everything else can be hot glued to the base without any problems.
Step 8: Build the Frame!
Take your marble run building supplies and build a loop for the marbles to "run" on. I just built a simple track, but this has endless possibilities. Maybe make a pinball machine. Maybe attach another conveyor belt to it! Just make sure that the ball gets back to the belt so it can do it all again.
Step 9: Finished!
You're already done! Congrats!
Here's a video of mine, with the aforementioned gear system to slow it down a bit.
It was fun building this, and it's sitting on my shelf giving marbles rollercoaster rides right now.
I'm thinking of building more marble loops, and attaching them to make a big marble run. We'll see ;D
See you around!
