Introduction: Improved Cooling of Cree Led H4 Headlight - DECOMMISSIONED.
Replacement of the stock cooling fans with an external air blower to give improved cooling for longer led life.
The leds I used are the newsun h4 headlight replacement from Amazon
http://www.amazon.com/dp/B00HFK2RAE/ref=sr_ph?ie=UTF8&qid=1415547515&sr=1&keywords=cree+led+h4
These lamps are legal in my country since the color temperature is 5000k and I adjusted the headlamps to put the light on the road and not in other drivers' eyes.
Step 1: 12 Volt Duct Blower Fan
Note the black silicone I applied to seal off the discharge of the fan so all the air goes into the hoses. You can use any color. Also I placed silicone to seal the top where the circuit board is for the fan.
Step 2: Garden Hoses for Cooling Air
Step 3: Hose to Led Heatsink
In the pic of the leds you can see the small cooling fans. These simply cannot cool a high power led using hot air within an engine bay. Unscrew them and slip on the 1 inch hose to get cool air directly over the heatsink.
Step 4: Monitoring of the Duct Fan
I needed to remotely monitor the fan while driving. Using a drok voltmeter ammeter from Amazon. I installed mines in the middle console. The current for my fan is 0.24amps. If it rises to about 0.30amps then that's a stalled fan condition. If it's zero amps then no power to the fan.
Update July 2016:
I have removed this cooling system and left the heatsinks passively cooled. The LEDs perform the same as before and this shows how well engineered they are. Also, since my engine bay was modified years ago, there is lots of free space for hot air to easily exit.
