Copper Dragon Egg
Intro: Copper Dragon Egg
Hello,
When I have seen the rextorn video, I decide to make my own copper dragon egg!
I make no photos of the egg construction :(, but the proccess is exatly the same as the rextorn video.
I will do photos for my next copper egg.
At the end and after 60 hours of work, the copper egg weighs 2,7 kg for 23 cm.
What you will need :
- Styrofoam egg 20 cm like this
- 4 copper plates 20cm*40cm*0.5 mm
- Gas torch like this
- Tin
- Sheet metal hand like this
- Metal polish like this
- Cement bag
- One plastic container 40cm*30cm*30cm
STEP 1: Do the Egg Print
With the cement, one container, and half of the styrofoam egg do the egg print.
But the cement and some water in the container.
Wait 3-4 min and use the styrofoamto make the egg print.
Wait 10-12 hours after.
STEP 2: Make the Copper Egg
Unfortunatly I take no photo of this...But it is not so difficult.
You will have to anneal the cooper.
You will find a lot of video on internet like this
Use the gas torch to heat copper and when it is red, put it quickly in water. Then you can use a hammer and the cement egg print to shape the egg.
You will have to repeat the process (anneal + hammer) a lot of time to get and half of copper egg.
When you have one half, let's go to make the other half.
When you have the two half, you can soldering them with some tin.
Weldone, You have make the most difficult!
STEP 3: Make the Scale
Now the proccess is exactly the same than Rextorn video
Before doing this, I make an example with the styrofoam and some paper.
I use 3 cuts of scale :
- 2cm*2cm => red paper
- 3cm*3cm => purpple paper
- 4cm*4cm => green paper
Use the sheet metal hand to cut the copper.
Use the hammer and the cement egg print to give some curve to the scale. Be carreful use some small piece of fabric because you don't want scratch the scale :)
Use the hand sander to make some curve on the scale.
STEP 4: Soldering the Scale on the Copper Egg
The proccess is exactly the same than Rextorn video
I use then gas torch to do the soldering.
I begin with the 2*2 sacle, then some 3*3, then all the 4*4, and then the rest of 3*3 scale.
My attempt with the styrofoam and some paper was very hepfull....
STEP 5: Finish the Copper Egg!
Before finish the egg, make a lot of example. You really doesn't want make a big mistake!!!!
For the black patina read this thread (in french).
1 => Use white vinegar too clean the egg.
2 => Use the black patina (I recommend to make a test before!!!!)
3 => Polish with the hand sander (Test the polish before used it on the egg)
4 => Use the metal polish (Again make a test before)
STEP 6: Find a Beautiful Box
To do :)
16 Comments
Dennis43 7 years ago
Nicely done to you and rextorn, Those are absolutely gorgeous eggs.
Mholmen 7 years ago
ClaudiaC57 7 years ago
Stunning! Don't let the trolls bring you down, as you made a beautiful piece.
I had been hoping you'd made this out of styro and craft foam, then faux painted it using rub-n-buff, ala cosplay weapons -- though that would be nowhere near as robust. But, I think I see some new projects in my future...
cyprien35 7 years ago
The most difficult is to make the cooper egg. I think you can use a 0.3 mm copper plate instead of the 0.5 mm plate.
It will be easier to make the egg and robust enough to welding scales.
The 0.5 mm copper plate was good but a little too rigid.
Perhaps with 0.3 mm there is no need to anneal the plate...just need a good hammer :)
Patrik 7 years ago
Please do not steal photographs from someone else's video! Looks like every singel one of the copperwork photographs starting at Step 2 were stolen straight from the Rextorn video you mentioned.
It is NOT OK to pass off someone else's work as you own.
RichardWhereat 7 years ago
If I put this on a pyre with a coma patient, will I get a dragon?
TessB6 7 years ago
He stole the guy's screen shots from his video. Nothing seen is his so how can you say his egg is beautiful. It's not his!
Eh Lie Us! 7 years ago
Best one I've seen so far.
dhall-1 7 years ago
So you took a Styrofoam egg, pinned some post-it notes to it, then took 10 screenshots from someone else's video and called it your Instructable?
Did you even make this yourself?
Yes I make it myself!
But unfortunatly I didn't take photo of the process. I realize at the end that I can post the process :(
If you doubt, try to find on internet a cooper egg with a 30 cm flat ruler, or a cement egg print :)
silkier 7 years ago
How long will it take to hatch?
I dont't know... :p
NicolasC69 7 years ago
https://www.youtube.com/watch?v=TqF6n-kIugs
narrowyoureyes 7 years ago
Great egg! You should enter this into the wizarding contest!
CrazyClever 7 years ago
DIY Hacks and How Tos 7 years ago
Wow that looks nice.
