Copper Metal Window Plant Hanger
437
9
Introduction: Copper Metal Window Plant Hanger
Copper Metal Plant Hanger with stained glass
Step 1: Copper Metal Plant Hanger With Stained Glass
Using RG45 welding rods the 6 pieces were bent using a hand bender to obtain the desired shape. I next used an Acetylene and Oxy torch to braze the pieces together, both sides. I brazed a ring at the top and bottom, the top one to hang it by, the bottom for looks. I cut the stained glass, copper foiled it and using a soldering iron, soldered the stain glass to the metal frame. A circle was cut from oak for the base to set the vase on and the vase was glued to the base. A plant can now be put into the water filled vase and hung in the window, or outside on a porch to enjoy
Metal Contest
Metal Contest
Be the First to Share
    • Make It Bridge
      Make It Bridge
    • Game Design: Student Design Challenge
    • For the Home Contest
    2 Comments
    seamster
    seamster
    7 years ago on Introduction
    This looks pretty good!
    If you open this up to edit, there is a built-in tool (the "Edit in Pixlr" button when you select a photo) that you can use to flip your photos upright. Just a thought :)
