Copper Pneumatic Air Cannon
27,426
20
44
Introduction: Copper Pneumatic Air Cannon
How to create a powerful air cannon from copper pipe and fittings, for very little in the way of cash.
Step 1: Materials
Materials
1.5m (5ft) of copper pipe
One 22mm elbow
Two 22mm endcaps
Two 22mm elbows
One 22mm Ballvalve
One tire valve
Solder
Flux
Ammunition
All pipe in this project can be any diameter, however, as the pipe size increases, so does the bill .
A good chamber:barrel ratio by volume 1:2, however you can change this to suit your needs. A gun with a barrel which is either too long or too short will not be more powerful, but rather less. You can use the Gas Gun Design Tool Tool to find out this length. The ".GDT" file is the saved data for my gun.
As a UK based user getting copper is simple. Many plumbing and hardware stores stock it. I highly reccomend BES Gas and plumbing supplies. I suspect the situation is similar in the US. Ballvalves are very common, and can be bought from most plumbing stores.
Flux and solder will more than likely be available in the same store.
A tire valve can be got from any auto store, or ebay. I got 10 snap in tire valves off ebay for �3 posted. nd they are perfect for this project.
Step 2: Tools
Tools
A vice (and bench)
A powerdrill
A file or debrring tool
A pipe cutter
or A hacksaw. (If you are using a saw you will need a miter block)
A blowtorch and lighter
Old gloves, these will need to insulate you from hot pipe
An old newspaper, this will protect yor work surface and insulate you from hot pipe.
Wet + Dry paper (a fine form of sandpaper)
A drillbit (for a standard schrader valve you will need a 5/16)
A fairly large spanner - My adjustable one was too small. I used a mole grip and wish I'd looked for a proper spanner.
A bike pump, for your valve.
Step 3: Preparation
As you have probably noticed my gun as a single strip of chamber, with 2 "branches" to stabilize it. It is an over-under design. The total length of your stabilisers will need to be a bit longer than your upright bit. The longer the stabilisers are, the more stable your gun will be.
A good chamber:barrel ratio by volume 1:2, however you can change this to suit your needs. A gun with a barrel which is either too long or too short will not be more powerful, but rather less. Don't forget to include all the pipe including the stabilisers in your volume estimation.
After you have cut the pipe to the size you want , you must remove the burrs, as these will hinder your soldering. The cut needs to be clean and straight.
Step 4: Adding the Valve
You will need to fill the chamber somehow. To do this you drill a hole in the endcap and glue in the valve. Mark the center of the endcap and clamp it in a vice. Get your drill. A standard schrader valve is around 5/16", but the hole will need to be a little larger if you're using a snap in valve. Save yourself some time and make sure you use a power drill and vice.
Step 5: Soldering
This is the hardest part.
1/ Solder works best if both the pipe and the fitting are really clean. Use fine wet and dry or wire wool to get all the surfaces shining.
2/ Flux should be applied to both the end of the pipe and to the inside of the fitting. Use a brush, flux is nasty stuff it rots skin and once its on your hands you will get it every where and that’s how you pipe starts to go green. All you need is a thin coating, think of how thick lipstick goes on and that’s about what we are after. To be honest we are talking about a strippers lipstick but you get the idea.
3/ Assemble the parts to be soldered. Remember for really strong joints you want to solder all of them at once. You may need to rig up a bit of a jig to hold everything straight and true but stay calm you can take ages over this bit the flux won’t go off. This is a good time to recommend the brand of flux I use, its called EverFlux and I use it because it isn’t active until you heat it, this is important if you might want to adjust stuff a few time before you solder as active fluxes will make fitting and pipe stick together in a few minutes.
4/ Solder is drawn towards the heat if you have to solder an elbow with one joint pointing down its Ok just do the other joint first and the heat will help with the difficult one. Heat the pipe first, do this until you just see it change colour, this takes a few seconds maybe 10 with 15mm and progressively longer as you use larger pipe. Now heat the area just beyond the joint, for instance on an elbow heat the bend. Again wait for the colour change and apply solder opposite where you are heating, you should see it melt and be draw into the joint. Don’t use too much solder you want to be aiming to use a similar length to the diameter of the pipe you are using as a maximum. More solder wont help it just falls into the fitting and starts to block it up. Now heat the other piece of pipe in you fitting and then back to the middle and again with the solder.
5/ LET IT COOL DOWN!! Only cowboys use a wet rag to cool pipes, don’t rush it.
6/ Clean your joints, if you can clean the inside as well. You don’t want all that nasty green stuff everywhere.
7/ If in you don't feel confident try using solder ring or Yorkshire fittings, the flux bit is the same but you don’t need to add solder. Heat a little above the joint line until you see solder all round and then stop.
Credit to Cornishtiger of The UK Spudgun Community (who is a professional plumber) for the excellent soldering guide.
Step 6: Adding the Valve
The valve will be a compression fitting. Put the pipe into the correct valve port and tighten it. The olive (metal ring inside) will compress around the pipe meaning it won't move. This will form a seal.
Step 7: Fire!
My favourite ammunition for a 22mm barrel is an empty 12g CO2 cartridge. But you can use anything which fits in the barrel. Close the ball valve, pump it up and release the valve. Power will change depending on how big you made your gun. The faster you open your valve, the better your shot will be. Pumping your gun with the valve open results in cool compression condensation rings. Have Fun! and be safe.
There are several places to find out more across the web.
*UKSGC
*Spudtech
*Spudfiles
Are probably the 3 largest
The Instructables Book Contest
Be the First to Share
    • For the Home Contest
    • Game Design: Student Design Challenge
    • Make It Bridge
      Make It Bridge
    44 Comments
    DanTDM
    DanTDM
    9 years ago on Introduction
    Spudtech is also spudfiles. The links are damaged.
    Biopyro
    Biopyro
    Reply 13 years ago on Introduction
    If by sweat you mean solder, then yes.
    struckbyanarrow
    struckbyanarrow
    i didn't know soldering or sweating would hold pressure. will try in the future!
    Biopyro
    Biopyro
    It certainly does. At higher diameters, the pipe itself will burst before the solder joint does.
    Biopyro
    Biopyro
    I believe they're the same thing under a different name.
    flashanimator
    flashanimator
    If i were to make something like this, i've made pvc air cannons before, could you take a 1/2" piece of copper pipe about 1 or 2 feet long, put an end cap with the tire valve on it, and on the open end just use either A) a ball valve and another piece of pipe for the barrel, or B) use a coupler and reducer to make the barrel even smaller, or bigger.
    So the design would like -----------OOOOO-    with the dashes being the barrel abd the zeros being the air chamber and last dash being the valve. Also could you use pvc cement to join the pipe together or do you have to solder it.
    Biopyro
    Biopyro
    Yes you could do it in that layout, but to connect copper to PVC you would have to use a threaded joint.
    Something like a 22mm x 3/4" M adapter (soldered to the copper) would allow the copper to screw into a 3/4" threaded ball valve.
    If you want to use PVC for the barrel you may as well use it for the whole cannon. There's not much point using both because then you just have the price and heaviness of copper AND the fragility of PVC.
    deNZil90
    deNZil90
    Would Mild steel work or is it best to use copper piping?
    Biopyro
    Biopyro
    mild steel would work, but the ends need to be threaded or you have to weld it. I chose copper because it's available, and lighter (not as thick)
    deNZil90
    deNZil90
    welding is not going to be a problem just wanted to make sure that its going to be safe thanks
    Biopyro
    Biopyro
    22mm copper has a safe working pressure of 51 bar. Even if you did take it high enough to cause damage (60-70 bar), it would swell, then split. At lower pressure ABS splits without swelling, and at 60 bar, if you got it that high, it might split catastrophically. TL;DR yes, but ABS is still very safe IF IT HAS A PRESURE RATING ON THE SIDE
    MJRSnyder
    MJRSnyder
    13 years ago on Step 4
    how do u attach the valve at the back?
    Biopyro
    Biopyro
    Reply 13 years ago on Step 4
    What do you mean "at the back"? You can buy "snap-in" tire valves off ebay or from an auto parts store. You drill a hole a little larger than the stem, then pulle the tire valve through with pliers. It should seal perfectly above 1 bar.
    Bugman9
    Bugman9
    14 years ago on Introduction
    iounce shot my airgun at my bike 50 feet away and it came back at my head and got me.
    i wanna do that
    ermm i have a question, i live in the uk and i cant find pvc ball valves at all, firstly can a metal ball valve be used on pvc piping and what glue did you use to stick the bike valve to the end cap? Because i am thinking of jus making a simple staright cannon(chamber with end cap woth the bike valve on it,which leds to ball valve which leds to the barrel) thank you and write back please
    Biopyro
    Biopyro
    Reply 14 years ago on Introduction
    I used a metal ball valve, what's the problem? I used only a little epoxy glue. If the hole is a good fit then the force of the air against the rubber around the base of the valve will push it against the rest of the endcap. Hope this helps :)
