Introduction: Correcting the Issue With On-board EEPROM for the BTT GTR V1.0
NOTE: this has been corrected with the most current versions of Marlin.
As it is; when the I2C EEPROM is enabled and trying to save to it or initializing it will cause the board reset.
Well, I decided to try the build that BTT provided on Github with the GTR
Marlin-bugfix-2.0.x BTT_GTR_V1.0-Demo
Editing the pins_BTT_GTR_V1_0.h file
- Removed // in front of #define I2C_EEPROM in the pins file.
- Added this code just below;
#ifdef E2END #undef E2END #endif #define E2END 0x1FFF // EEPROM end address 24C64 (64Kb = 8KB)
Configuration.h
- Removed // in front of #define EEPROM_SETTINGS
Complied and flashed this firmware to the GTR. Flash worked with no resetting issues.
Marlin 2.0.5.3
EEPROM failing then board reset just after.
Next, I tried an external I2C EEPROM in the I2C (J65) got the same results.
Checking files I finally came across comparing the GTR Demo Marlin from BTT and the current Marlin 2.0.5.3 and found this file under \buildroot\share\PlatformIO\variants\BIGTREE_SKR_PRO_1v1\variant.h
In the BTT Demo it has this;
//I2C Definitions #define PIN_WIRE_SDA PH5 #define PIN_WIRE_SCL PH4
· In 2.0.5.3 it has this;
// I2C Definitions #define PIN_WIRE_SDA PB7 #define PIN_WIRE_SCL PB6
The BTT Demo has the correct pins that are connected to the on-board EEPROM.
So in 2.0.5.3 variant.h I changed the code to the following;
// I2C Definitions
#if STM32F4X_PIN_NUM >= 176
#else
#endifStep 1: Final Code Changes for 2.0.5.x for the BTT GTR On-board EEPROM to Work.
// I2C Definitions
#else
#endifConfiguration.h
#define EEPROM_SETTINGS // Persistent storage with M500 and M501<br>//#define DISABLE_M503 // Saves ~2700 bytes of PROGMEM. Disable for release! #define EEPROM_CHITCHAT // Give feedback on EEPROM commands. Disable to save PROGMEM. #define EEPROM_BOOT_SILENT // Keep M503 quiet and only give errors during first load #if ENABLED(EEPROM_SETTINGS) //#define EEPROM_AUTO_INIT // Init EEPROM automatically on any errors. #endif
pins_BTT_GTR_V1_0.h
#define I2C_EEPROM //#define SRAM_EEPROM_EMULATION // Use BackSRAM-based EEPROM emulation //#define FLASH_EEPROM_EMULATION // Use Flash-based EEPROM emulation #ifdef E2END #undef E2END #endif #define E2END 0x1FFF // EEPROM end address 24C64 (64Kb = 8KB)
![How to Load New Firmware on [BTT] Bigtreetech TFT Displays](https://content.instructables.com/FCM/ENW4/K8LRQ8UD/FCMENW4K8LRQ8UD.png?auto=webp&crop=1%3A1&frame=1&width=130)
