Introduction: Cosy Cottage
If you've started a new world and you want to start off with a simple house, then this is just the thing for you!
Step 1:
Make a 7 by 7 hole that is 2 blocks deep.
Step 2:
Fill in the walls and floor but build one of the walls out of bookshelves.
Step 3:
Build a 5 high pillar in each corner.Then fill the floor in (you should be able to stand in the bit underneath).
Step 4:
Build a layer of planks then put glass pane on top of that then 2 more layers of planks on that.Remember to leave a space for the door.Also the glass panes can't be touching the gap for the door.
Step 5:
Put a row of 3 oak stairs underneath the door.Put 2 fence going up on the outer stairs.Then place another row of 3 oak stairs on top facing downwards.Don't forget to put the door in.
Step 6:
Place and oak block on each side of the top.The place more going up and diagonally until the meet.Then fill the inside with oak planks.
Step 7:
Put in all the stairs and slabs on top of all the oak.
Step 8:
Put a trapdoor in the corner and 2 ladders leading down to the basement.
Step 9:
Then decorate the house in any way you like.
