Introduction: Covid Live Report Using Raspberry Pi
As we know the whole world is being affected by COVID-19 pandemic and almost everyone is working from home. We all should utilize this duration at best, to improve our technical skills or writing some good Pythonic scripts.Let’s see a simple Python script to demonstrate the state-wise corona virus cases in India. This Python script fetches the live data from Ministry of Health Affairs Official Website.
Raspberry pi 3 b+
SD Card(min 16GB)
HDMI cable
Ethernet cable
internet connection
if you are first time in raspberry pi you need to setup it:- https://projects.raspberrypi.org/en/projects/raspb...
other requirementviusal stdio code(python ide) link here:- https://visualstudio.microsoft.com
Step 1: Raspberry Pi Setup
Make Sure the OS Is Installed on the SD Card. Your SD might have Raspberry Pi Operating System installed. ...Configure the Wifi Connection on Your SD Card. ...Turn on Your Raspberry Pi. ...Connect to Your Raspberry Pi with SSH. ...Install VNC Server. ...Install a VNC Viewer on Your Laptop.
To run a program
Before we start writing the software we first need to install the Raspberry Pi GPIO Python module. This is a library that allows us to access the GPIO port directly from Python.
To install the Python library open a terminal and execute the following
pip install python-rpi.gpio python3-rpi.gpio
With the library installed now open your favorite Python IDE and paste this code or try yourself
Step 2: You Need to Install Some Additional Features for It They Are:-
pip install bs4
pip install tabulate
pip install matplotlib
pip install numpy
you need to open command prompt, to go search button and enter cmd and open with Run as administrator
Step 3: Importing Libaray
# importing libraries
import requests
from bs4 import BeautifulSoup
from tabulate import tabulate
import os
import numpy as np
import matplotlib.pyplot as plt
Step 4: Collecting Live Data From Ministry of Health Affairs Official Website.
extract_contents = lambda row: [x.text.replace('\n', '') for x in row]
URL = 'https://www.mohfw.gov.in/' SHORT_HEADERS = ['SNo', 'State','Indian-Confirmed', 'Foreign-Confirmed','Cured','Death']
response = requests.get(URL).content soup = BeautifulSoup(response, 'html.parser')
header = extract_contents(soup.tr.find_all('th'))
stats = [] all_rows = soup.find_all('tr')
for row in all_rows:
stat = extract_contents(row.find_all('td'))
if stat:
if len(stat) == 5:
# last row
stat = ['', *stat]
stats.append(stat)
elif len(stat) == 6:
stats.append(stat)
stats[-1][1] = "Total Cases"
stats.remove(stats[-1])
Step 5: Creating Table to Show the Output
objects = []
for row in stats : objects.append(row[1])
y_pos = np.arange(len(objects))
performance = []
for row in stats :
performance.append(int(row[2]) + int(row[3]))
table = tabulate(stats, headers=SHORT_HEADERS)
print(table)
Step 6: Now You Can See That Report
Remember it is live report so there is change in every time
