Introduction: Cozy 3Dprinted Lamp
About: I'm trying to make fun 3D models that are usefull and fun.
This is a budget lamp to place on your night stand. It gives a nice atmosphere to the room and is clear enough to read a book.
  • Cap
  • Stand
  • LED
  • LED connector
  • Cable
  • Switch
  • Screw fitting
Step 1: Assembly
The assembly is very straight forward. The top en bottom part fit perfectly on top on another.
For the fitment you will have to push it in the hole of the screw fitting. After you have done that you can screw it in the two assembled pieces. That’s the assembly done.
For the cables it is also quite easy, just connect the connectors to the cable of your choosing. Just don’t forget to put the switch in between.
Step 2: How It Should Look
Step 3: Files
