Introduction: Cozy Candy Cabin
This candy cabin in the autumn woods is entirely edible. If you like chewy licorice and gummy worms, you might also enjoy munching on the leaf-filled tree tops.
Twizzlers Hershey's Chocolate Twists
Twizzler's Licorice Twists
Twizzler's Pull 'n' Peel (Cherry flavored)
Gummy Worms Gummy Candy
Chickles (minis) Jelly Candy
granulated sugar
confectioner's sugar meringue powder
water
brown food coloring gel
1 plastic 10" cake board
1 spatula (icing spreader)
1 paring knife
1 pair kitchen scissors
cutting board or plate
measuring spoon
measuring cup
1 teaspoon
small saucepan
mixing spoon
mixer with whisk attachment
1 large mixing bowl
1 small bowl
tea towel
roll of black electrical tape
Step 1: Preparing the "logs"
Log cabin structure:
Cut 26 pieces of 4 inch long chocolate twists logs.
Cut 26 pieces of 2 1/2 inch chocolate twists logs. These shorter logs will fit between the long logs.
Step 2: Mix Royal Icing Chinking
Chinking is the material used between the logs when building a log cabin. Chinking creates a nice seal between logs which don't perfectly fit together. In this case, royal icing serves chinking for a candy log cabin.
Recipe for royal icing:
4 cups or 1 lb. of confectioner's sugar
3 tablespoons of meringue powder
5 tablespoons of water.
Put these three ingredients in a large mixing bowl. Use a whisk attachment and mix at medium speed for approximately 7-10 minutes until peaks form.
Cover the bowl with a damp tea towel to keep the icing from drying out.
Step 3: Color Chinking
Put part of the royal icing in a small bowl and add brown food coloring gel.
Stir until food coloring gel is throughly mixed.
Step 4: Foundation of Log Cabin
Lay out 4 of the 4 inch chocolate candy logs as shown.
Using a paring knife, spread chinking (royal icing) on top of the candy logs.
Step 5: Add Logs
Add two long (4 inch) chocolate logs on top of base.
Add two short ( 2 1/2 inch) chocolate logs between the two long logs.
Cover the logs with chinking (brown royal icing).
Step 6: Continue Building
Keep adding layers of two long logs and two short logs and then cover the tops of the logs with chinking (brown royal icing) until all the chocolate logs are used.
Step 7: Reinforce the Cabin
With a paring knife, spread a layer of chinking (brown royal icing) on the inside walls of the cabin.
Step 8: Add Upper Walls for Roof Support
Cut 7 chocolate logs (starting with a 3" log as the base). Notice the logs form a triangular shape and have notches along the edges.
Using chinking (brown royal icing), attach the 7 pieces to the front and back sides of the cabin as shown.
Step 9: Support Upper Walls
After the triangular wall piece on the front of the cabin is in place, spread chinking (brown royal icing) on the inside of the triangle and then press extra chocolate log twists into the royal icing to add stability.
Repeat this step on the back side of the cabin and allow to dry.
Step 10: Cabin Roof
Cut 9 pieces (each 4" long) from Twizzlers pull 'n' peel cherry candy.
Spread chinking (brown royal icing) on the notches of the triangular upper wall.
Place one 4" candy log at the top of the roof to make the ridge.
Then place 4 more candy logs from the front of the cabin to the back.
Complete the other side of the roof using chinking (brown royal icing) and 4 more candy logs.
Note: To fill any roof gaps, pull apart 1 Twizzler pull 'n' peel and place the single "shoe-lace" strands between the 9 large rolled candy pieces.
Step 11: Base of Tree
Bundle 8 pieces of Twizzler licorice twists together.
Cut 3 pieces of black electrical tape. Wrap the first piece of tape around the base of the 8 candy twists.
Then put the second piece of tape about 1" higher than the base tape. Wrap the third piece of tape no higher than 4" from the base.
Using scissors, level the base of the tree by cutting away excess candy so the tree will stand upright. Be sure to leave 4" for the upper branches.
Repeat two more times to make 3 trees.
Step 12:
With kitchen scissors, snip the upper candy twists lengthwise, making 16 tree branches as shown.
Repeat two more times.
Step 13: Gummy Worm Autumn Leaves
Diagonally snip thin pieces of gummy worms to create a lot of colorful fall leaves.
Step 14: Royal Icing Snow
Uncover the bowl of royal icing and using an icing spatula, generously spread a layer of royal icing snow around the log cabin.
Be sure to cover the entire plastic cake board.
Step 15: Adding Details
Trees: Insert 3 trees into the royal icing snow. Add extra icing around the base of each tree to ensure stability.
Front door: Using two green mini Chuckles, squish together and flatten the gumdrops. Cut a rectangle and stick to the front of the cabin with royal icing. Add a tiny licorice door handle.
Stepping stones: Cut apart two black mini Chuckles (gumdrops) and press into royal icing.
Window: Flatten 2 yellow Chuckles and cut out a square. Repeat for second window. Attach the windows to the sides of the cabin with royal icing.
Chimney - Cut 1 black Chuckles diagonally on the base and attach on side of roof with royal icing. See finished picture for chimney.
Leaves- Press gummy leaves into the royal icing around the base of the trees and the log cabin.
Step 16: Attaching Leaves to Tree Branches
Mix up a batch of edible clear sugar glue:
1/2 cup white granulated sugar
1/4 cup water.
Put sugar and water in a small saucepan. Stir.
Heat mixture on low to medium setting on stove top until it thickens.
Take off heat.
Using a small spoon, dribble sugar glue onto the tree branches and attach gummy leaves.
Work quickly before glue hardens. Be careful as sugar glue is hot!
Step 17: Finished!
Now you have learned all the steps needed to build a log cabin - well, an edible one anyway.
Maybe it's time to sample a little bit of the roof...
