Introduction: Cpx Face Shield
Our team created a device using a circuit playground express that will serve as a face shield for the user to protect against viruses. With button activated lights and lifting capabilities this device is sure to provide safety and protection to the user.
For this project you will need
Adafruit Circuit Playground Express (CPX) CircuitPlaygroundExpress
USB to micro B cable UsbToMircoBCable (apple user’s will need USB type c to micro B cable)
Lithium Ion Battery - 3.7V 2000mAh LithiumIonBattery
Makerbot PLA + 3d printer
a laptop/computer
Velcro strap (1 inch width) (Supplied by makerspace) or 24-x-1-inch-cinch-straps-with-eyelet-5-pack
Clear sheet of plastic
3 alligator clips
A hot glue gun
Tape
pliers/tweezers
MU editor (coding software)
Step 1: Ensure That Circuit Python Is Installed on Your Device
If you do not already have this, follow the instructions provided in this link to help you get started. InstallCircuitPython
Step 2: Connect CPX
Connect CPX to your computer as seen in the photo below using the USB connector
Step 3: Attach the Alligator Clips to the Proper Connector on the CPX
The alligator clip that attaches to the orange wire of the servo, you must attach to the circle labeled A2 on the CPX
The alligator clip that attaches to the brown wire of the servo must attach to GND
The alligator clip that attaches to the red wire must be clipped to Vout
Step 4: Copy the Code
Copy the code below then open your Mu editor. Once open, paste code onto your Mu editor
Step 5: Save to Device
Once the code is copied to your Mu editor, press the save button seen below. In the picture the location of the save button is circled.
Step 6: Print CPX Case
Follow the link below and print it to your 3d case. When printing, make sure to request supports otherwise the objects will not print properly.
Step 7: Remove Excess Material
Once the file is printed, because of the breakaway supports you will need to take pliers or tweezers to remove the support materials.
Step 8: Add Head Strap
Once the excess material is removed, attach the CPX holder by sliding the velcro strap through the ports on the sides of the CPX holder as seen in the picture below
Step 9: Fit Velcro Strap to Your Head
Readjust the velcro strap to fit comfortably around your forehead to ensure the CPX face shield will be secure on your head.
Step 10: Attach Servo
Next, attach the servo to the spot on the top of the 3d printed case and add hot glue to completely secure the device. The servo should be able to fit perfectly into the case.
Step 11: Add Battery
Place the battery into the case followed by the CPX on top. Connect the battery to the black port to the left.
Step 12: Attach Plastic Sheet
Attach the plastic film sheet to the side of the long 3d printed object. The sheet should be attached the same way as the picture with the majority of the plastic sheet hanging in the opposite direction of the little piece that sticks up on the band.
Step 13: Attach Servo
Attach the small partextension of the 3d printed visor band piece to the servo motor by taping it to the white arm as seen in the photo or by adding in a small screw.
Step 14: Now You're Ready
To use, place the device on your head with the plastic part covering your face. To raise the shield, press button A, to lower the shield, Press button B.
