Introduction: Crafted Broken Branch Waterfall Fountain | How to Make Waterfall (DIY)
Welcome to our captivating DIY project: the Amazing Broken Branch Waterfall Fountain! In this unique and imaginative endeavor, we will guide you through the steps of crafting a stunning waterfall fountain using unexpected materials – a dead branch and packaging styrofoam. With a touch of creativity and a dash of innovation, you'll transform these seemingly ordinary items into a mesmerizing focal point for your garden or living space. Prepare to embark on a journey of artistry, as we combine nature and recycling to create a soothing oasis right in your own backyard. Join us as we unveil the secrets to crafting this enchanting Branch Waterfall Fountain, a testament to the power of DIY ingenuity and sustainable design.
- Wooden Branch
- Styrofoam piece
- 3watt water pump
- Cement
- Artificial Moss and Plants
- Dried Mosses
- Terracotta Pot
- GI wires
- Ply Board
Tools
- Solder iron
- Glue gun
- Wood Glue
Step 1: Branch Transformation
- Select a branch of suitable length.
- Mark the desired location on the branch with a marker.
- Employ an angle grinder to create a channel through the branch.
Step 2: Water Hose Installation
- Apply a lacquer to seal the branch's pores and ensure airtightness.
- Insert a 10mm softpipe into the channel.
Step 3: The Base Creation
- Begin with a 16"x10"x4" thermocol sheet.
- Simultaneously create two craters on both sides using a soldering iron. The left crater was made to hold the branch and the right one was made for the pond to accommodate the pump.
- Use a hot air gun to provide an abstract and textured appearance to the thermocol.
- Enhance stability by affixing a plywood panel underneath using adhesive glue.
- Allow it to dry for a day before proceeding.
Step 4: Base Modification
- Apply a cement wash to the base.
- Securely attach the branch using cement on the left crater.
Step 5: Terra-pot Installation
- Pre-drill the terracotta pot and attach a Galvanized Iron hook to the neck.
- Enhance its appearance with artificial grass.
- Hang it securely on the edge of the branch.
Step 6: Water Pump Installation
- Utilize a 3-watt water pump.
- Secure the water pump with the softpipe.
Step 7: Beautification
- Enhance the aesthetics by incorporating moss into the base.
- Add artificial plants to further beautify the setup.
Step 8: Final
In conclusion, our DIY Bonsai Tree Waterfall Fountain showcases the beauty of repurposing materials and unleashing creativity. This project emphasizes sustainability while enhancing your living space. We hope it inspires you to embark on eco-friendly DIY endeavors, creating enchanting additions to your surroundings. Thank you for joining us in this journey of imagination and innovation.
PS. please watch the detailed video for more information.
Unusual Uses Contest
