Introduction: Crank Flashlight Charger
Learn how to turn a crank flashlight into your own personal charger!
Step 1: Take Apart Your Crank Flashlight
Remove all screws and separate the two pieces of plastic, covering the flashlight.
Step 2: Get a Charger for Your Desired Phone
Cut the cord closest to the connector that goes into the wall. Once you have done this, you will need to take off some of the casing, exposing the inner wires of the cord. In our case we used a USB cord and cut off the USB port to reveal our wires.
Step 3: Removing the Circuit Board
Unscrew and remove the circuit board from the crank shaft while also disconnecting the blue auxiliary wires from the circuit board. Allowing them to be connected to your charger's excess wires.
Step 4: Putting It All Together
After exposing the blue auxiliary wires and your charger's wires, inter twine the negative blue auxiliary wire and the negative wire coming from your charger together. Then inter twine the positive blue auxiliary wire and the positive wire coming from your charger. For best results, it is recommended that you use electrical tape to secure the wires together. (Alligator clips are also an options and work as well.)
WARNING: do not crank too quickly for you may cause damage to your charging port due to the lack of resistors. ( removed with the circuit board previously)
