Create Homemade Fluorescent Black Light/UV Displays
Intro: Create Homemade Fluorescent Black Light/UV Displays
Black lights (formally, Ultraviolet or UV lights) are just fun. Not only are they great for when you are in a trance, but they can be used to identify those questionably unidentifiable stains on your bf's or gf's clothes. But the coolest thing is how certain colors or chromophores react with UV lights. Whites and fluorophore compounds (chemical side chains responsible for fluorescence) are especially colorful under a good UV lamp or array of UV LEDs.
In this instructable, I'll show you how to create your own fluorescent compounds out of something you probably already have in your home.
STEP 1: Gather Your Items
What's the first thing that comes to mind when thinking about fluorescent ... well, besides fluorescent lighting? Fluorescent markers, that's what! Otherwise going by "Hi Liters" or some such thing, these humble little buggers are just screaming to be used for something besides highlighting organic chemistry text books. And we're going to listen to their plea.
Grab some highlighters from your desk, bureau, backpack, friend's locker, mom's credenza...you know, wherever. They're lying all about if you really look for them, those unassuming little pearls hiding right in front of our piggish noses. You can use the big fat ones or the slimmer bic-type highlighters, depending on how much fluorescent solution you want to make. The slim versions are fine to make about 150mL to 200mL, depending on how much highlighter fluid is in the highlighter pen. The fat highlighters can make upwards of 500mL of fluorescent solution.
Now, go get 'em!
Now, go get 'em!
STEP 2: You've Got to Get to the Marrow
For this step, break open your hilighters. I've found some pop off easily from the rear (I should retype that sentence) while others offer a bit of a struggle. For the overdoer in our crowds, grab your dremel and cut that sucker open. That's what I do. Any occasion to cut anything open I use the faithful dremel. I like it so much I have three, just so I can cut three things open at once. Seriously.
Anyway, check out some of the pictures.
Once you have the pen broken open, cut open, or otherwise dissected, you should find a fibrous center shaft that contains the ink. Be careful and don't squeeze it when pulling it out of the pen's shaft. Be prepared to transfer it immediately into a reservoir of water. Being a biochemist, I use 150mL autoclave bottles but you can get by with anything as long as it's watertight. For the water, I use distilled water at ambient room temperature (~ 25 Celsius) but again, for the less anal retentive, you can get on well with just tap water. Regarding temperature, I've tried warm water to increase the rate of transfer of ink into water, but something about my brain prefers ambient to cool water. Don't use ice water, m'kay?
STEP 3: Soak the Ink Shafts
You've got the fibrous ink shafts out, so drop it in your waiting 150mL or so container of H2O. It's more prudent to use less water than more, as you can always dilute it later if it's too concentrated. You know it's too concentrated because it won't fluoresce. If this happens to you, just add more water to dilute the solution until a UV LED casts a solid shaft of light through the fluorescent solution and causes the rest of the fluid to fluoresce nicely. You'll know it when you see it.
Soak those ink shafts for a while, at least until the fibrous shafts are blanched clean/white. Personally, I soak for about a day or two, but you can probably get most of the ink out in several hours. Try turning the bottle every now and then or agitating the solution -- not by calling it names or hiding its homework, but by shaking it gently back and forth.
When the shafts are blanched pull them out and check the concentration with a UV LED and proceed to dilute if necessary. You probably won't need to if you use a thin highlighter. I've found that even thick yellow highlighters make a very bold fluorescence in 150mL while the same concentration in another color doesn't fluoresce at all. Try yellow, green, pink, blue, or any other color that you find and like.
Tighten off your bottles and save them back as your fluorescent stock to use in fun and interesting LED/blacklight lamp projects.
STEP 4: Some Ideas
You can fill bottles (like empty clear bottles, especially neat if antique or laboratory looking) with your fluorescent solution and just put them somewhere, like a stand or curio cabinet or the top of your cabinets next to your beer bottle collection.
Another idea is to take clear plastic tubing and hold one end with your thumb while you pipette or use an eye dropper to aloquot solution into the tube. It's a tricky endeavour as putting in the solution displaces air, which wants to go out your thumb side. Play around with it. When you're satisfied with the filling, cap off both ends with hot glue. Consider getting UV SMD LEDs and running magnet wire behind the tubing with your LEDs. It looks fantastic.
A final idea is to get some sort of scintillation vial (that's chemistry talk for a small vial with a screw-on, watertight cap) and:
- drill two holes in the cap
- take a 5mm UV led and thread the leads through the holes
- seal off the metal with silicon glue of any variety (i use "tough as nails")
- seal off the cap inside
- fill up the vial with your favorite fluorescent solution
- screw on the lid, adding more solution until there's no bubble
- now connect 3-5V via a 120 ohm resistor to the LED
STEP 5: Conclusion
I hope you've enjoyed this instructable. It's easy and inexpensive fun for you and the kids (just make sure they don't drink it). I hope I was able to share something new and fun with you. As always, I am open to comments and suggestions on this or any of my instructables.
Cheers!
-gian
/nev/dull
Cheers!
-gian
/nev/dull
32 Comments
corey11 13 years ago
nevdull 13 years ago
CathlynA 8 years ago
Hey hahahah thank u so much u helped me a lot. I have a problem with my previous research topic bc it's so hard to do and i did some browsing and i saw this. I created an account here just to thank u. THANK U VERY MUCH for posting this :))))))))))))
sabrina8579 9 years ago
do you think there is anyway to use this idea to make a blood splatter pattern naked to the eye and then use a uv light to show it im trying to find a way to make my class project cool! thanks anyone have ideas you rock
nwkeeny 9 years ago
Very cool instructable, thank you. I have a question and perhaps you can help me. Do you have any idea of what homemade fluorescent powder I can use to detect theft? We have had poaching on our game farm, and yesterday we found an animal still ensnared. I'd love to be able to put a powder on it's hair and see what comes from it.
nevdull 9 years ago
Hi,
Thanks for the nice words. I'm not sure I understand what you're wanting to do with the fluorescing substance. Are you thinking something akin to the dye packs found in bank vaults?
ceciliapham02 9 years ago
hi do you need a light to make it glow or can you just turn off the lights and it will glow on its on like a glow stick
nevdull 9 years ago
a glow stick produces its characteristic glowing through chemiluminescence and not fluorescence. remember, fluorescence immediately reemits absorbed light, so you need a light source.
mguerriero1 10 years ago
La cacatua carmesi 11 years ago
When i turn them on it's awesome.
Great instructable!!
nevdull 11 years ago
Thanks for sharing!
-gian
Daxuto 11 years ago
I definitely like the ideas you have here, good job ^.~
Sounds like you have a neat project on your hands...anything with "vortex" in its name has got to be pretty cool. :)
Thanks a lot!
cantfollowinstructions 12 years ago
thanks
nevdull 12 years ago
You might have better luck looking for a UV fluorescent tube. Use with caution!
Good luck!
SharpyWarpy 12 years ago
There are several places out on the Intertubes where you can get these little bottles (called "scintillation vials") but here's a link from a science project supply store that has several types of bottles that could potentially be used.
http://www.sciplus.com/category.cfm/subsection/7
Good luck!
nafreena 12 years ago
Good luck!
